HF injectors different from Si?
Old Oct 21, 2006 | 12:33 AM
sporkcrx's Avatar
Default HF injectors different from Si?
Their part numbers are different, but that's for the sets, so I dont know if one of the seals are different or something. Basically can I use HF injectors on an Si motor?
Old Oct 21, 2006 | 12:39 AM
ndondahows's Avatar
Default Re: HF injectors different from Si? (sporkcrx)
i believe all stock honda injectors are the same exept if the OBD is diff
Old Oct 21, 2006 | 07:30 AM
BlueCrxNC's Avatar
They ARE different. 88-89 are ~190 cc while 90-91 HF and all others are 240cc (or greater for other model Hondas)
I owned 89 CRX HF injectors (original from my car) and they couldn't handle the JDM D15B VTEC and P28.. (bogged down lean; Felt like I was out of gas). I put in the OBD1 Injectors from the D15B motor and removed the injector resistor box and all was fine... After a year I went back to the old Peak and Hold (OBD0) injectors... bogged down... purchased used Si injectors and it ran fine. Went and had the old HF injectors tested and they were around 190cc
Old Oct 21, 2006 | 08:54 AM
sporkcrx's Avatar
Default Re: (BlueCrxNC)
it's an 88 HF so it looks like I'll be finding some new injectors, thanks for the help!
Old Oct 21, 2006 | 08:58 AM
superhatchbackbros's Avatar
i got a set of injectors. 240cc
Old Oct 21, 2006 | 01:07 PM
sporkcrx's Avatar
Default Re: (superhatchbackbros)
already found some, but thank you
Damills
Mar 3, 2009 02:56 PM
driftam1
Apr 21, 2008 10:19 AM
shadycrx
11
Jan 2, 2006 07:03 PM
junkyardRx
Sep 6, 2004 04:02 AM
SOHCrx
Nov 27, 2003 07:39 AM
