Suspension & Brakes Theory, alignment, spring rates....
Driveshaft: Outboard Joint + Knuckle
Old Oct 20, 2006 | 11:27 PM
K-Spec's Avatar
Default Driveshaft: Outboard Joint + Knuckle
So I was having this problem before:
the caliper was rubbing against the rotor.
and then I removed my wheel tonight and found the two screws holding the rotor to be loose so I tightened those up, but then I saw this...and was wondering if this looks normal.
this is a pic of the outboard joint connected to the knuckle (sorry for the blurryness)
What do you guys think?
K-Spec
Oct 21, 2006 10:53 PM
K-Spec
Oct 21, 2006 03:18 PM
K-Spec
Oct 21, 2006 08:41 AM
slowteg550
Suspension & Brakes
Jul 21, 2006 07:30 AM
opiumdaze
Oct 11, 2005 09:27 PM
