How do you remove a 1985 hatchback OEM radio unit?
I looked at some car radio installation guides, but no luck because it is completely different from mines. I dont have pictures though. But is the radio really attached to a screw or can I just pop it out? If there are screws, how do I unscrew it from the bottom? There seems to be a wall blocking it. If possible, would audio shops charge me free of money if I just ask them to remove the radio? Or at least tell me how to? Help!
in my old 88, there were 3 screws holding it in place start by removing the ash tray that should give you a little more view there should be two screws at the back of the head unit that can be removed with a stubby phillips head, also you might have to be use a little focre(carefully) with the wiring harness directly under the head, the remove the anteanna connection, then the harness, you can find adapters most any where, my accord 88 hatch harness fit my 95 ex. hope this helps--------No-No
dm2350
Nov 8, 2010 08:47 PM
