Car will need Maintence job. What should i do?
Old Oct 20, 2006 | 09:34 PM
Import_spoon's Avatar
Default Car will need Maintence job. What should i do?
Hi everyone i'm new to honda-tech. I own a 1995 Acura integra Ls manual. I was wondering what should i change or do to make it back to maintence and everything, so the car will be up to date. I recently just got this car. All that is done on this car is a oil change thats it. Please help me what to change or to make it up to date. Thank you.
Old Oct 20, 2006 | 10:00 PM
lsvtek's Avatar
Default Re: Car will need Maintence job. What should i do? (Import_spoon)
uhh... Timing belt, valve adjustment, check exhaust for any holes or anything, little things
Old Oct 21, 2006 | 09:45 AM
Default Re: Car will need Maintence job. What should i do? (4drlsintegra)
oh alright. How much do you think that will cost? Kinda on a budjet right now since i just got the car.
Old Oct 21, 2006 | 06:17 PM
Sam92Teg's Avatar
Do yourself a favor and go to your nearest autoparts store and buy a Haynes manual for your year integra. Best $15 you will spend for your teg. All the suggested maintenance is listed with mileage intervals and how-to instructions, so you can try doing the simple stuff yourself and saving a few bucks.
Old Oct 21, 2006 | 07:03 PM
Default Re: Car will need Maintence job. What should i do? (Sam92Teg)
Oh ok thank you very much.
Old Oct 21, 2006 | 08:47 PM
harrykong's Avatar
buy a extra book its good to sit on when your reading and doing the maintenance 2nd best 15 dollars youll spend
Old Oct 21, 2006 | 10:34 PM
gsr dood's Avatar
Default Re: Car will need Maintence job. What should i do? (harrykong)
the main things to do when u first buy a car IMO is to 1- spark plugs 2- Spark plug wires 3- cap/rotor(dizzy) 4 - oil change ... all that should cost you about $100 and only requires very minimal knowledge of cars. anybody can do this stuff. if you need help just ask us. thats wat HT is for
Old Oct 22, 2006 | 05:48 AM
Default Re: Car will need Maintence job. What should i do? (gsr dood)
Thank you very much. All you guys here are very helpful.
Old Oct 22, 2006 | 06:06 AM
ivicr's Avatar
Its gonna take time to restore the kar and make it "up to date". Just have patience, its all worth it in the end. I suggest upgrading where possible, lots of parts kost only slightly more then and sometimes cheaper then stock parts.
Im trying to do the same with my 97 LS. Good Luc !
Old Oct 22, 2006 | 06:20 AM
Racermech's Avatar
Default Re: Car will need Maintence job. What should i do? (ivicr)
How many miles are on the car? Do you have any maintance history of the car?
Old Oct 22, 2006 | 06:34 PM
Oh yeah. Nice and slow will get you there someday. lol Gl on yours too.
Old Oct 22, 2006 | 06:35 PM
Default Re: Car will need Maintence job. What should i do? (Racermech)
its got 172xxx miles, i have all the maintence and repairs that was done to the car. The car was women owned in 1994 all the way to 2003 or 2004.
Old Oct 22, 2006 | 07:22 PM
Racermech's Avatar
As you have all of that information look over i and put a little pictuer tougher, First Has the timing belt been changed? If so when? It might be due again. When was the plugs, fuel filter,wires, cap rotor changed. Has the tranny fluid been changed?
Once you determine the age of the parts it will give you a better idea of when you need to change what.
Old Oct 22, 2006 | 07:45 PM
na+b18c_hatch's Avatar
i work at an acura dealer. every 30,000 miles we do oil/filter, air filter, trans fluid, tire rotation, brake/clutch fluid flush, valve adjustment, parking brake adjustment, spark plugs (cap, rotor, and wires every 60,000). coolant flush every 45,000 miles. and at 105,000 (alot of people still do it at 90,000) is the timing belt and water pump. hope this helps.
Old Oct 22, 2006 | 07:58 PM
The last maintence paper was at 15x,xxx miles. Its at 172xxx miles. Everything was checked ok if they were fine or if they needed changes they were changed.
Old Oct 22, 2006 | 07:59 PM
Default Re: (ItR_98)
Since you worked there and all the things you listed, how much would that cost me? I'm still trying to get more money from buying my Integra so i just need some basic tune up thats all.
Old Oct 22, 2006 | 09:37 PM
toshiro's Avatar
I bent my Wookiee
Maintenence is not the same thing every time. Try to figure out what kind of maintenence was done at 150xxx before you decide what the car needs next.
Old Oct 23, 2006 | 04:52 AM
Default Re: (toshiro)
what happens if there might be a maintence at 16xxxx and she never added that paper? would skipping anything would be alright?
Old Oct 23, 2006 | 07:17 AM
civic91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ItR_98 &raquo;</TD></TR><TR><TD CLASS="quote">i work at an acura dealer. every 30,000 miles we do oil/filter, air filter, trans fluid, tire rotation, brake/clutch fluid flush, valve adjustment, parking brake adjustment, spark plugs (cap, rotor, and wires every 60,000). coolant flush every 45,000 miles. and at 105,000 (alot of people still do it at 90,000) is the timing belt and water pump. hope this helps. </TD></TR></TABLE>
30,000 miles oil/filter????
Old Oct 23, 2006 | 04:23 PM
I decided to take out and clean where the coolant go and when i was pouring into a cup, it was like all watery and really really dark green for the first cup. The second cup had some gooy stuff in it and it was darker then the first. Was it a good thing i cleaned that out? Would i have to clean the coolant that has gone into the block?
MyceliuM
Nov 1, 2004 07:43 AM
IntegraBoy04
Sep 17, 2003 05:48 PM
cialz
Oct 7, 2002 05:19 PM
kepani
Mar 4, 2002 09:03 PM
Scooby
Jun 27, 2001 09:13 AM
