RC injectors
Old Oct 20, 2006 | 09:05 PM
SiRay13's Avatar
Default RC injectors
Im in the process of putting in new injectors, rc550's and aem high flow fuel rail, im not sure if i have the right injectors or if they are just designed light this but I can not get a tight seal when i put the injectors into the manifold, i have not bolted down the fuel rail, but it just seems odd that the oem injectors have a tight seal to the point that you have to pull on the injector with some force to get it to come out of the manifold, these injectors don't have that kind of seal, using the rc supplied seals also. has anyone else experienced this?
Old Oct 21, 2006 | 06:47 AM
SiRay13's Avatar
Default Re: RC injectors (SiRay13)
bump
Old Oct 21, 2006 | 04:30 PM
si 2's Avatar
yea i know what your talking about i put some rc 440's in my crx and the seal didnt go in the hole so i said screw it tightend the fuel rail down really good and it pushed the seals around the edge snug the car fired up and runs. works fine i would just say tighten the fuel rail down and it should be fine. let me know what happens
SolAssassin
Nov 23, 2009 03:20 PM
integralactic
Jul 26, 2007 07:59 PM
( o )( o )
12
Sep 20, 2005 06:05 PM
abeaujuin
Sep 4, 2003 08:05 AM
