vtec question
is it normal for vehicle to blow a little bit of black soot when vtec has engaged? i have searching around and i have heard that while vtec has engaged, mixture goes to a full rich (100%) condition, causing the black soot. Is this true?
89 CRX with d16z6 engine 151xxx KM on the engine. could also use a tune-up, original wires, cap and rotor, and o2 sensor, worn plugs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndondahows »</TD></TR><TR><TD CLASS="quote">it is a little normal because the ecu will dump more fuel when vtec kicks to check black smoke means you are running rich anyway and thats better than lean</TD></TR></TABLE>
Are you running the motor OBD-1?
yes, converted from obd-0 to obd-1
black soot @ 6000+ rpm under hard acceleration.
and another question, the distributor rotor is held on by a screw/bolt, and seems very difficult to remove. I almost stripped it with a philips, any suggstions?
reconstructdead
Aug 22, 2005 09:47 AM
