Camber kit Trouble?
Old Oct 20, 2006 | 04:29 PM
1lowsol2's Avatar
Default Camber kit Trouble?
I can't get that upper control arm off, The bolt won't come out of the hole. How do you get it out? Withsome kind of press? By the way its on a 94 Sol and the camber kit is TSUDO
Old Oct 20, 2006 | 04:30 PM
1lowsol2's Avatar
and i know my sig says camber kits are for pussies but my tires are waering really bad in the front lol.
Old Oct 20, 2006 | 04:33 PM
B16b-EJ8's Avatar
perhaps you should change your sig then...on another note it should just come out...you back out the bolts on both sides from inside the engine bay just like any other bolt.
Old Oct 20, 2006 | 04:35 PM
1lowsol2's Avatar
no i have them unbolted and i have the complete strut out i know how to take it apart i just dont know how the Upper control arm? Or upper A-arm wich ever thats called The main bolt, I dont know how to get that out, It just dont slide right out of the hole.
Old Oct 21, 2006 | 08:21 AM
UberMunkey's Avatar
Default Re: (1lowsol2)
are you talking about the upper ball joint?
Old Oct 21, 2006 | 08:24 AM
Sleepy_Red_hatch's Avatar
Default Re: (UberMunkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UberMunkey &raquo;</TD></TR><TR><TD CLASS="quote">are you talking about the upper ball joint?</TD></TR></TABLE>
uhhh post pics, once the assembly is out of the strut tower, their should be no more work involved....
Old Oct 21, 2006 | 09:53 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1lowsol2 &raquo;</TD></TR><TR><TD CLASS="quote">and i know my sig says camber kits are for pussies but my tires are waering really bad in the front lol. </TD></TR></TABLE>
Probably because you have massive toe-out.
Post your alignment print-out.
Old Oct 21, 2006 | 02:46 PM
1lowsol2's Avatar
i have like a -3.something in the front and yeah im talking about the upper ball joint
Old Oct 21, 2006 | 03:58 PM
UberMunkey's Avatar
they make tools to pop ball joints, but if you don't have acces to one you're probably going to have to resort to hammering it loose.
Old Oct 21, 2006 | 04:01 PM
tha_badguy's Avatar
you gotta press it out...
& use should change ur sig unless u now consider urself a *****
Old Oct 21, 2006 | 04:33 PM
EJ6_ROY's Avatar
Default Re: (tha_badguy)
If you'r e just talking about removing it from the damper fork, then tap it with a hammer. Mine took a little convincing, but overall, it wasn't difficult. there are only two other bolts on the entire A-arm, so i'm sure you can figure it out
Modified by rniederlando at 1:09 PM 10/25/2006
Old Oct 22, 2006 | 04:12 PM
1lowsol2's Avatar
yeah i've had those out plenty of times, It made it easier putting the strut back on, Aight well When i go to attempt to put them on again ill try beating that botl a lil.
And yes i'll change my sig when i put my camber kit on lol. I just cant afford to pay 400$ for tires every year.
russianswty
Mar 9, 2007 10:26 PM
LilMrTinnie
Apr 26, 2005 03:48 PM
turbotime
Apr 14, 2005 09:00 AM
Standard One
Mar 4, 2004 06:40 PM
1bar
Aug 21, 2002 04:06 PM
