Plz is this car ABS or NON - ABS ?????????
look under neith the hood, does it only have the master cylinder for the brakes,
or is there another setup for the braking system.
Look in a repair manual and see what a abs unit looks like, then pop the hood and
see if it has it or not.
Also you can look at the ends of the axles and see if it has an abs ring on there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN. »</TD></TR><TR><TD CLASS="quote">4dr 90-93 Integra with rear disks</TD></TR></TABLE>
All '90+ Integras have rear disc brakes. Whether it has ABS or not will depend on the trim level; for '90-93 4-door Integras, only the GS trim had ABS. The '90-93 4dr RS and LS trims did not have ABS.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">4dr 92-95 Civic EX with rear disks</TD></TR></TABLE>
All '92-95 EX 4drs have ABS. They also all have rear discs.
OBD revision has nothing to do with it.
Why are you asking?
Why are you asking?
if his car is non-abs, it wont matter if he gets ABS rear brakes from 90-93 integra ?
if his car is ABS, he will need to get ABS rear brakes ????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN. »</TD></TR><TR><TD CLASS="quote">if I bring the VIN #, could you tell if is ABS or not</TD></TR></TABLE>
Yes, I could tell you if I ran the VIN through the computer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">I am asking because I want to get a non abs brakes for a friend</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">if his car is non-abs, it wont matter if he gets ABS rear brakes from 90-93 integra ?</TD></TR></TABLE>
No, it will not matter. The rear discs from an ABS car will bolt right up and work fine on a non-ABS car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">if his car is ABS, he will need to get ABS rear brakes ????</TD></TR></TABLE>
Yes, if he has ABS, he will need the parts from an ABS car because they include the wheel speed sensor. I doubt that he has ABS though, since the only ABS Civics that came without rear discs were '96+ models.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">All '92-95 EX 4drs have ABS. They also all have rear discs.
Why are you asking?</TD></TR></TABLE>
Nope, not ALL 92-95 EX Civics had rear disc brakes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN. »</TD></TR><TR><TD CLASS="quote">if his car is non-abs, it wont matter if he gets ABS rear brakes from 90-93 integra ?
What is his car, does it have ABS or not?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">Nope, not ALL 92-95 EX Civics had rear disc brakes. </TD></TR></TABLE>
All '92-95 EX 4drs had rear discs and ABS. He was asking about the 4dr model specifically.
You are correct about the EX in general - '93-95 EX 2dr models were non-ABS and had rear drums. '94-95 EX-ABS 2dr models had rear discs.
You are correct about the EX in general - '93-95 EX 2dr models were non-ABS and had rear drums. '94-95 EX-ABS 2dr models had rear discs.</TD></TR></TABLE>
There is the specification I was looking for. Good research.
Go in some mud or a icy parking lot and slam on your brakes, if you hear this horrible rattling sound and your peadal pulses, you have ABS, if you hit the concrete wall, you dont lol.
