HELP!! once again my oil light comes on and stays on but
Old Oct 20, 2006 | 02:22 PM
FastAzzDA's Avatar
Default HELP!! once again my oil light comes on and stays on but
HELP!! once again my oil light comes on and stays on but the oil is new and it has the right amount of oil in there
Old Oct 20, 2006 | 02:27 PM
FastAzzDA's Avatar
Default Re: HELP!! once again my oil light comes on and stays on but (FastAzzDA)
what could be the problem i'v checked everything out but i havent figured it out and if any one knows the engine codes please give me some help with that, thanks
Old Oct 20, 2006 | 02:34 PM
92integraVTECgsr's Avatar
could be the sensor. have u checked that?
cause if you say you have the right amount of oil in it, then my first guess would be the sensor.
Old Oct 20, 2006 | 02:53 PM
martyball619's Avatar
Default Re: HELP!! once again my oil light comes on and stays on but (92integraVTECgsr)
try resetting your ECU..
Old Oct 20, 2006 | 03:07 PM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
Oil lights sometimes come on when you have low oil pressure, which is usually caused from not having enough oil. In your case you might wanna check that circuit or you may be having oil pressure problems. Hooking up a gauge would narrow down whether its oil pressure or not...
MyUsernameName
Jun 15, 2017 02:06 PM
itzyaboyzeem03
Jul 1, 2016 04:40 PM
kseriesdreams
22
Jan 30, 2011 04:31 PM
toyH22
May 31, 2006 02:05 PM
livelife46290
Jul 14, 2004 05:15 AM
