Jdm Front End Question....
Old Oct 20, 2006 | 02:09 PM
99DCteG's Avatar
Default Jdm Front End Question....
ok so im doing the JDM front end conversion on my 99 teg LS and i wanna know if your using just the T-Bar off the JDM rad support, do you need to get the JDM bumper reinforcement bar, or can the stock bumper be used? if not does the Jdm bumper reinforcement bar work with the rest of the USDM rad support? same with the bumper support.. does that work with the USDM rad support? or should i just put the whole rad support in and not use just the T-bar off it? I was tryin to save a little time by just usin the t-bar..
Old Oct 20, 2006 | 03:12 PM
trick_db's Avatar
Default Re: Jdm Front End Question.... (integras_are_best)
you clearly doesnt know what your doing
try hmotorsonline.com and passwordjdm.com
they have complete front end ready to be installed, all you have to do is buy it, bring to a shop and they will know what to do with it.
Old Oct 20, 2006 | 07:43 PM
99DCteG's Avatar
Default Re: Jdm Front End Question.... (trick_db)
ok. well ill just figure it out by myself if you dont wanna answer my ques. all i was asking is<U>"IS THE T-BAR ON THE JDM RADIATOR SUPPORT THE ONLY THING DIFFERENT FROM THE USDM RADIATOR SUPPORT?"</U> i have everything i need to do it except a hood latch cable. and ill post up pics after its done by BY ME!
Old Oct 20, 2006 | 07:51 PM
99DCteG's Avatar
ok nvrmind.. but answer this question can u use the oem bumper or do you have to get the one off password?
Old Oct 20, 2006 | 08:03 PM
vinai's Avatar
there is an article on how to do it using the usdm bumper plus the jdm extension piece. I'm going to try it when I get enough time. If you want the article email me at crzyazian@gmail.com
Old Oct 20, 2006 | 11:57 PM
Naruto's Avatar
Default Re: Jdm Front End Question.... (vinai)
To answer your question....I'm not sure. But I believe it would be since there are people on here that have only used the "T" portion of it. I would seriously recommend you weld it on or get someone to weld it on no matter what for safety reasons. By "it" I mean the JDM radiator support.
Old Oct 21, 2006 | 12:18 AM
OneOhNine27's Avatar
yes theres a slight difference with the radiator mount. The front end wont fit right without it.
gospeedgo1
Jan 11, 2007 10:45 AM
SLR ef9
19
Feb 20, 2006 10:23 AM
jdm phantomx
Jan 16, 2005 02:34 PM
ef9one6
18
Jul 12, 2003 06:34 AM
moss
Aug 8, 2001 03:56 PM
