DIY HID questions
Old Oct 20, 2006 | 01:45 PM
corrupt0r's Avatar
Default DIY HID questions
I am looking to do this conversion in the near future on my '97 EX Coupe
I am planning on retrofitting projectors and have a few questions:
1. Is it ok to use the stock headlight, (this is with respect to the lense) I understand the whole point of retrofit is to put projectors into a housing that does not have OEM HID's. To elaborate do I need a TYC(i think this is the brand) style housing with the very clear lense or will my stock ones work well enough if I buff the crap out of them?
2. How does the HID work with high/low beams...most conversions i see only account for the lowbeam or so it seems( are high beams even neccessary if you have an HID system in this situation?)
3. What brand of ballast/ignitor is reccommended?
4. Also, what projectors have seemed to work the best for those who have converted?...I've found A6 and TSX ones to be pretty common and easily found.
5. Can someone point me towards any DIY's...i think i found one in search but all the pics were red x'ed
6. Finally, I understand that the #K denotes color but is this determined by bulb or projector...pretty sure i remember seein bulb but no 100%...I will most likely be using 4100 4300 or 6000 depending on my mood at the time of purchase...(dont't worry i wont be goin for the purple or anything dumb)
thanks in advance
Old Oct 20, 2006 | 02:02 PM
NonovUrbizniz's Avatar
Loved
Default Re: DIY HID questions (corrupt0r)
- If the stock lenses have grooves in them then NO you cannot use them... they will scatter the light essentially making the projectors NOT projectors.
- High/Low function depends on the HID/Stock set up you have... If you get Bi-xenon projector HID's that have a high and low setting then you need to wire them to work... If you get a single function projector (low only) then you need to use the stock highbeam... of course that only works if there IS a stock highbeam left after you fit in the Projector.
In my project I'm prob. going to run high/low HID's (bi xenon) AND a halogen high beam... when the lows are on it will be projectors only... once the highs are on it will be HIGH projector together with the high beam halogens.
- Ballast/Ignitors... just get everything all together.. that's the easiest... get bulbs/ballasts/prjectors all in one. or at least the projectors and the ballast together.
- Projectors I BELIEVE are all just about the same size... so I don't think there is a prefered specific set.
- http://www.hidplanet.com/forums/
Go to the "university" section... it's got GREAT info... and it REALLY informs you
- I don't really have time to link here... I'll try to remember to through some links up when I get home.
- The temperature/light range is dictated by the bulbs... I can't remember what the ideal range is but I think it's around 4500-6k...
Good Luck
Oh here's my work in progress thread... Unfo. I haven't done ANYTHING else with this project since I posted that thread...
https://honda-tech.com/zerothread?id=1557330
Old Oct 20, 2006 | 03:36 PM
CarbonizedDX's Avatar
Default Re: DIY HID questions (NonovUrbizniz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz &raquo;</TD></TR><TR><TD CLASS="quote">- If the stock lenses have grooves in them then NO you cannot use them... they will scatter the light essentially making the projectors NOT projectors.
<u>There is no one best for ballasts/ignitor units, it all depeins on the install. Me personally I like to use Hella Gen 3's</u> - CarbonizedDX edit
- Projectors I BELIEVE are all just about the same size... so I don't think there is a prefered specific set. <u>- Depeding on the projector, they will range from 2" to 3" diameters, most are 2 1/2" single xenon and 3" bi-xenon. Projector Choice boils down to money and desire</u> CarbonizedDX edit
- <u>&gt;&gt;http://www.hidplanet.com/forums&lt;&lt;</u>
<u>Go to the "university" section... it's got GREAT info... and it REALLY informs you</u>
- The temperature/light range is dictated by the bulbs... I can't remember what the ideal range is but I think it's around 4500-6k... <u> OE is 4300k , but some like a little whiter light and I'd say upto 5000K is still safe n good but with HID bulbs. I got 4300K pnp's in my trep and the output is nice n white (have a feeling they're more 5000K's but ohwell)</u>
Good Luck
https://honda-tech.com/zerothread?id=1557330</TD></TR></TABLE>
+1
Old Oct 20, 2006 | 05:08 PM
corrupt0r's Avatar
thank for the informative reply...i will definitely check that out when i get a chance...
one more question:
1. how long would you estimate someone with no dremel exp and intermediate mechanical skills to do this conversion
Old Oct 20, 2006 | 05:33 PM
Carbonyl's Avatar
Default Re: (corrupt0r)
all i have to say is, get another set of headlights if you plan on driving around at night while doing a retrofit because it takes a long time to get things how you want it with no experience. I would say a good few days to get things how you want it.
edit: if you need some HID stuff, I can probably get some for you depending on what you want. I just got some 06 Lexus RX330 headlights complete with ballast and bulbs. It will be posted for sale soon
edit 2: now up for sale
Modified by Carbonyl at 6:56 PM 10/20/2006
Old Oct 20, 2006 | 05:53 PM
t0p_sh0tta's Avatar
Default Re: (Carbonyl)
^ do you have any Bixenon projectors available?
Old Oct 21, 2006 | 06:48 AM
Loved
Default Re: (t0p_sh0tta)
Search EBAY... they're all over there for pretty good prices...
example:
http://cgi.ebay.com/ebaymotors...QrdZ1
I'm not endorsing that particular seller... but that's all hte parts you're looking for.
Also... keep in mind that if your just putting the bi-xenon projectors in place of already existing projectors (like in aftermarket headlight housings) then it COULD be as simple as removing the old projector and installing the new one... then figuring out where to put the ballast.
Here are some links I have on my home machine:
Require log in:
http://www.hidplanet.com/forum...=4636
http://www.hidplanet.com/forum...e5be9
https://honda-tech.com/zerothread?id=612520
https://honda-tech.com/zerothread?id=1340157
I can't remember since I haven't looked at this project in a while... but most of those you REALLY need to read the ENTIRE thread.
Old Oct 23, 2006 | 11:57 AM
corrupt0r's Avatar
http://cgi.ebay.com/ebaymotors...wItem
something like this seems to be all i can find as a replacement...i am going to need a set with non-fluted (i believe this is the correct terminology) lenses and all i can find are the crazy looking black housings or even worse crazy lookign chrome ones
at least with this i think i woudl be able to use a halogen high beam as it appears to have two light sources rather than just the one with off center bulbs like oem
has anyone had success finding a different set of headlights or perhaps just simply swapping lenses from an aftermarket set of headlights?
Old Oct 23, 2006 | 12:12 PM
hondaboy4life's Avatar
just find the ek or w/e style headlight that looks oem but has a black housing on ebay and sue that... oem look...clear lense.
Old Oct 24, 2006 | 11:24 AM
corrupt0r's Avatar
Default Re: (hondaboy4life)
do you have an example...all i can seem to find are the crazy "jdm blakc housing projectors" i would def prefer a more oem look
Old Oct 24, 2006 | 01:43 PM
http://cgi.ebay.com/ebaymotors...sting
something like that. Search around, find the kind like that that u like, they will all pretty much be like that though. By getting these u can work on ur hid retro and still have lights on ur car
It would be sweet to buy the black housing headlights with the ion lense too while ur at it, i think those look dope.
Old Oct 25, 2006 | 06:32 AM
corrupt0r's Avatar
both of the links you posted wouldnt work...first one is still a fluted lense which scatters the hid projectors rendering the projector part useless...and the seconds i dont think will fit on the 96-98 civics
Old Oct 25, 2006 | 06:37 AM
well i was justusing them as examples, and the 1st one i posted only has some parts that r fluted, but where the light will b projected its clear.
Old Oct 25, 2006 | 07:33 AM
mike1114's Avatar
go to HIDplanet.com for all your HID needs. It's like the HT of HID.
my Euro Golf IV projectors in 92-95 tyc headlights.
Old Oct 25, 2006 | 07:34 AM
mike1114's Avatar
If you SEARCH, you can find all kinds of write ups, inlcuding mine with LOTs of pics.
Old Oct 25, 2006 | 09:54 AM
TehMan's Avatar
Default Re: (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">go to HIDplanet.com for all your HID needs. It's like the HT of HID.
thats hot
Old Oct 25, 2006 | 10:32 AM
corrupt0r's Avatar
that def looks very nice...i will most likely go with one of the crazy tyc ones with a black housing and experiment until i get it exactly how i want it...since i am getting new housings it will give me however much time is neccesary to get it done correctly...and i am startin to read the hidplanet info as i am posting this...
thanks for all who helped...but more info is always welcome
matt21civ
Honda Civic (2001 - 2005)
Jul 24, 2006 05:29 AM
D-series ninja
Sep 5, 2005 03:33 PM
EX-JAY
Mar 19, 2005 07:50 PM
Hatchtrap
Feb 2, 2003 06:08 AM
VSM EXtasy
Oct 15, 2002 01:01 AM
