How to install the S2000 steering wheel onto EK civic
Old Oct 20, 2006 | 01:11 PM
Plum_civicEK's Avatar
Default How to install the S2000 steering wheel onto EK civic
as title, and yes i know there was a thread about this and i've read that already. but the pictures in that thread are gone so it'll be easier if someone else can provide me more info on step-by-step along w/ picture (WORKING PICTURE DAMN IT).
thz for the help in advance
Old Oct 20, 2006 | 01:13 PM
Default Re: How to install the S2000 steering wheel onto EK civic (Plum_civicEK)
as a matter of fact, i'll post up the old thread for the DIY instruction.
https://honda-tech.com/zerothread?id=817033
as you can see the pic is dead and i want to see some picture on the step-by-step installation.
Old Oct 20, 2006 | 01:14 PM
iDeNtiTy
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Plum_civicEK &raquo;</TD></TR><TR><TD CLASS="quote">as a matter of fact, i'll post up the old thread for the DIY instruction.
as you can see the pic is dead and i want to see some picture on the step-by-step installation.</TD></TR></TABLE>
pics dont work
Old Oct 20, 2006 | 01:23 PM
Default Re: How to install the S2000 steering wheel onto EK civic (Type-Ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-Ek &raquo;</TD></TR><TR><TD CLASS="quote">
pics dont work</TD></TR></TABLE>
i think you should pay attention to what i said and read my post.
I SAID THE PIC ARE DEAD!!!!
Old Oct 20, 2006 | 01:51 PM
NonovUrbizniz's Avatar
Loved
IM the guy he says in the post his image station folder is getting full...
he's still an active user... so I'm sure he'd be willing to help you out if he still has pics...
Old Oct 20, 2006 | 02:00 PM
Default Re: How to install the S2000 steering wheel onto EK civic (NonovUrbizniz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz &raquo;</TD></TR><TR><TD CLASS="quote">IM the guy he says in the post his image station folder is getting full...
hmm.........good idea, i wonder y i didn't though of that. lol
anyways, i'm open for more opinion, another DIY instrustion would be nice.
Old Oct 20, 2006 | 05:09 PM
bump, still need help
Old Oct 20, 2006 | 05:33 PM
BlueIntegraBoy's Avatar
1. Disconnect negative terminal on battery for 10 mins.
2. Make sure wheel is straight.
3. Remove side panels on the Civic wheel.
4. Unplug the SRS plug from the airbag.
5. Take a T30 torx bit and remove the two screws holding in the airbag.
6. Unplug the horn and cruise control (if applicable) wires from the plug.
7. Loosen, but do not remove, the 19mm nut on the steering column.
8. Holding hands at 9 and 3, give the wheel a quick jerk to pop the wheel off the column.
9. Remove the nut and wheel.
10. Place the S2K wheel onto the EK steering column and feed the SRS, horn, and cruise (if applicable) through the center of the hub.
11. Bolt back the 19mm nut.
12. The horn and cruise (if applicable) might need some modifications to work with the Civic wires. Just match the wire colors.
13. Bolt the airbag back on.
14. Connect the SRS plug.
15. Replace side panels.
16. Reconnect terminal on battery.
Old Oct 20, 2006 | 06:59 PM
Default Re: How to install the S2000 steering wheel onto EK civic (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">1. Disconnect negative terminal on battery for 10 mins.
16. Reconnect terminal on battery.</TD></TR></TABLE>
that seems easy enough, but still kinda hard to picture when I haven't really try taken the steering wheel apart by myself. thz for the info though. :D
Old Oct 20, 2006 | 07:01 PM
The instructions are pretty detailed and this is what usually is written in a Helms manual. Take it step by step.
Old Oct 20, 2006 | 07:36 PM
Pnoyej6's Avatar
* B A N N E D *
i have momo steering wheel on my ek an dthe horn doesnt work. whats wrong?
Old Oct 20, 2006 | 07:54 PM
Eran's Avatar
HT White Ops
Default Re: How to install the S2000 steering wheel onto EK civic (pnoytegn707)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pnoytegn707 &raquo;</TD></TR><TR><TD CLASS="quote">i have momo steering wheel on my ek an dthe horn doesnt work. whats wrong?</TD></TR></TABLE>
Unless it came in an S2000 ... that's not really relavent. It could be various things, the horn, the relay, your clockspring, etc.
Old Oct 20, 2006 | 08:22 PM
https://honda-tech.com/zerothread?id=273474
http://importnut.net/civicsteeringswap.htm
orientalgunz_00
Sep 24, 2012 05:51 PM
ej6.sean
32
Sep 24, 2012 05:40 PM
goldenmustache
Sep 5, 2009 07:31 AM
Danethomp
Oct 5, 2006 07:20 AM
R33DelSol
Aug 10, 2004 06:16 PM
