1991 si swap: distributor question.. help?
Old Oct 20, 2006 | 01:09 PM
eknorcal's Avatar
Default 1991 si swap: distributor question.. help?
i'm not sure on this but my brother is swapping a 94 ls into his 91 si hb. he says he can use his stock 91 si distributor for the 94 ls swap.. can anyone confirm this? or does he need a 91 ls distributor? thanks
Old Oct 20, 2006 | 01:15 PM
dr_latino999's Avatar
Default Re: 1991 si swap: distributor question.. help? (eknorcal)
Well he CAN (with modification) use a D16A6 distributor, but would I advise it? No. Just do it right the first time and call it a week.
Old Oct 20, 2006 | 11:47 PM
eknorcal's Avatar
Default Re: 1991 si swap: distributor question.. help? (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Well he CAN (with modification) use a D16A6 distributor, but would I advise it? No. Just do it right the first time and call it a week.</TD></TR></TABLE>
oh like any specific mods? anybody else?
Old Oct 21, 2006 | 04:04 AM
Sikocivic's Avatar
94 B18 is OBD1, 91 Si is OBD0. You will either have to change the motor to OBD0 or the car to OBD1. I don't know how you would get the Si dizzy to bolt up to the B18 motor.
Old Oct 21, 2006 | 09:14 AM
Default Re: 1991 si swap: distributor question.. help? (Sikocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sikocivic &raquo;</TD></TR><TR><TD CLASS="quote">94 B18 is OBD1, 91 Si is OBD0. You will either have to change the motor to OBD0 or the car to OBD1. I don't know how you would get the Si dizzy to bolt up to the B18 motor.</TD></TR></TABLE>
1) It doesn't matter what "OBD level" the motor is as it only matter what distributor + ECU combination is used. If both are the same generation, it could be OBD-2021 for all it matters.
2) Start chopping off legs / making the bolt holes slotted, eventually it'll fit. This is why I said it was possible, but I still wouldn't recommend it.
Old Oct 21, 2006 | 11:07 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eknorcal &raquo;</TD></TR><TR><TD CLASS="quote">i'm not sure on this but my brother is swapping a 94 ls into his 91 si hb. he says he can use his stock 91 si distributor for the 94 ls swap.. can anyone confirm this? or does he need a 91 ls distributor? thanks </TD></TR></TABLE>
He could hack it and halfass it onto there, but anyone with a brain would just source a used distributor from a '90-91 B18A1. There are plenty of '90-91 Integras sitting in junkyards, especially in California.
Old Oct 22, 2006 | 09:01 PM
eknorcal's Avatar
thanks a lot everyone
HybridRacer69
Mid-Atlantic (Sales)
Dec 28, 2005 04:57 PM
415Hatch
Jun 4, 2005 11:21 AM
89civichatchback
Jan 22, 2005 12:35 PM
s520player
Jun 20, 2003 01:36 PM
