b18c5 or b16b camshaft?
Old Oct 20, 2006 | 12:53 PM
pepengagimat's Avatar
Default b18c5 or b16b camshaft?
guys im confused.. im rollin with my all motor b16a engine in a 4door civic running 14.1et with stock pistons,stock camshafts, programmable ecu, 22 M/T slicks.. recently i installed a set of b16b pistons for higher compression. and im thinking which one will give me a better result.. using b18c5 camshafts or b16b's?
i forgot, im using a 4.4 final drive tranny
also do guys have the specs for both of the cams?
Old Oct 22, 2006 | 12:01 AM
blinx9900's Avatar
Default Re: b18c5 or b16b camshaft? (pepengagimat)
b16b cam
Old Oct 22, 2006 | 06:03 PM
civicjdmb16a's Avatar
Default Re: b18c5 or b16b camshaft? (blinx9900)
<U>Following Cams Measured at 1mm of lift: </U>
Integra Type-R (98 ITR)
Int- 11.5mm lift / 240 dur.
Exh- 10.5mm lift / 235 dur.
Civic Type-R And Integra Type-R (01 ITR)
Int- 11.5mm lift / 243 dur.
90HFCrX
Jan 25, 2005 05:47 PM
Swapped_EG
Aug 12, 2004 03:52 PM
HotWheelz
Feb 21, 2003 04:58 PM
