remove transmission to fix throughout bearing squeak?
Old Oct 20, 2006 | 11:42 AM
Log4n's Avatar
Default remove transmission to fix throughout bearing squeak?
throughout bearing just started squeaking...when the clutch is not pressed in......can i get rid of the squeak without removing the transmission.........i know its not a permanent fix but just something temporary?
Old Oct 20, 2006 | 01:49 PM
Econo Appliance's Avatar
Default Re: remove transmission to fix throughout bearing squeak? (Log4n)
Good luck. My thorwout bearings ALWAYS squeak, even when they're brand new. forget about it.
Old Oct 20, 2006 | 03:56 PM
CardDealer's Avatar
Banned
Modified by CardDealer at 4:37 AM 11/16/2006
Old Oct 20, 2006 | 04:41 PM
1lowsol2's Avatar
I had mine replaced, Silent Transmissiion now BABY!
Old Oct 20, 2006 | 04:52 PM
Heretic:Si's Avatar
if you pull off your bumper, lift the radiator up and out of the way. you can pull off the boot and get some grease in there. i've done this before so i know it works.
ldyer1994
Apr 23, 2015 08:19 AM
Johnoolo
Nov 13, 2013 05:48 AM
ToTriggerHappy
May 3, 2010 04:50 AM
taylorjohnson11
Nov 14, 2007 07:40 PM
b16ahybrid
Nov 26, 2005 06:42 PM
