Loud Knock?
Old Oct 20, 2006 | 11:22 AM
DC2_ALL MOTA's Avatar
Default Loud Knock?
Ok I have semi built gsr motor in my dc2 with a b16a tranny. I was driving down the road, then all of the sudden I hear a loud *** knocking sound coming from my motor. Sounds like I spun a bearing again, but I don't think thats it. Before I had troubles getting my tranny into gear, and I believe it is because I had a spring pop out of my clutch disc. Only knocks when I get up to around 3k rpm's. Motor idles fine. Someone please verify this problem being my clutch. Thanx
Old Oct 20, 2006 | 11:49 AM
spun311's Avatar
Default Re: Loud Knock? (DC2_123)
I couldn't get my prelude into first gear when I spun a bearing on it. I don't know if the two are related or not tho.
Old Oct 20, 2006 | 11:54 AM
mugenDA9 lover's Avatar
what stage and brand clutch? it may just be the clutch ratteling from a bad release bearing
Old Oct 20, 2006 | 12:00 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2_123 &raquo;</TD></TR><TR><TD CLASS="quote">Ok I have semi built gsr motor in my dc2 with a b16a tranny. I was driving down the road, then all of the sudden I hear a loud *** knocking sound coming from my motor. Sounds like I spun a bearing again, but I don't think thats it. Before I had troubles getting my tranny into gear, and I believe it is because I had a spring pop out of my clutch disc. Only knocks when I get up to around 3k rpm's. Motor idles fine. Someone please verify this problem being my clutch. Thanx </TD></TR></TABLE>
I doubt it's the clutch. Drain the oil and hope it doesn't have metal shavings/metallic crap in the oil. Also, drain the oil through a fine filter just to make sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spun311 &raquo;</TD></TR><TR><TD CLASS="quote">I couldn't get my prelude into first gear when I spun a bearing on it. I don't know if the two are related or not tho.</TD></TR></TABLE>
Not related.
Old Oct 20, 2006 | 12:37 PM
Default Re: Loud Knock? (mugenDA9 lover)
I have a stage 2 xtd generic clutch. When I let off in 1st, it hesitates alittle and shakes. I'm really hoping its my clutch/tranny. I'll drain oil and see if my magnetic drain plug collects alot of metal.
Old Oct 20, 2006 | 12:39 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2_123 &raquo;</TD></TR><TR><TD CLASS="quote">I have a stage 2 xtd generic clutch. When I let off in 1st, it hesitates alittle and shakes. I'm really hoping its my clutch/tranny. I'll drain oil and see if my magnetic drain plug collects alot of metal. </TD></TR></TABLE>
a clutch issue would make it hard to get in gear. Transmission issue is possible however less likely.
Old Oct 20, 2006 | 12:41 PM
Default Re: Loud Knock? (skunked)
Im just worried about the knock issue. Also when I was driving, felt like the motor was stalling alittle, or clutch slipping.
Old Oct 20, 2006 | 12:43 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2_123 &raquo;</TD></TR><TR><TD CLASS="quote">Im just worried about the knock issue. Also when I was driving, felt like the motor was stalling alittle, or clutch slipping.</TD></TR></TABLE>
ouch, don't drive it anymore and drain the oil.
Old Oct 20, 2006 | 01:18 PM
projectTeG's Avatar
drain the oil and hope for the best.
Old Oct 21, 2006 | 04:32 AM
Default Re: (projectTeG)
Well drained the oil and of course with my luck theres about half inch of metal stacked on my drain plug and I could see the copper shavings in my oil pan. Soo angry!! I was hoping it would be my clutch since, motor idled fine and everything, but had to have spun a bearing again.
Old Oct 21, 2006 | 06:55 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
So what the heck causes a spun bearing to happen anyway?
Old Oct 21, 2006 | 09:43 AM
skunked's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">So what the heck causes a spun bearing to happen anyway?</TD></TR></TABLE>
Since it was just rebuilt it sounds like the clearances were incorrect.
That sucks
B18c1vicrx
Nov 10, 2007 09:42 PM
CalhounBoi
Jun 11, 2007 10:33 PM
JDMtype Eg6
Dec 16, 2006 04:53 PM
NosCivic01
Apr 25, 2006 03:37 PM
CRX_RUS
Jul 5, 2004 11:40 PM
