anyone have any pointers for sanding?
Old Oct 20, 2006 | 10:35 AM
baozer's Avatar
Default anyone have any pointers for sanding?
well i bought an oem spoiler from someone. i currently have an ek CX model and as you might know the cx wings are a little short so i purchased a DX wing. its a little bit longer and its also metalic. i just purchased some filler primer and some trim paint. i just wanted to know if anyone had any pointers on sanding. like what grit to use.. i know you use a big one first then a finer one after that.. any suggestions?
Old Oct 20, 2006 | 10:37 AM
mrtrinh's Avatar
Default Re: anyone have any pointers for sanding? (baozer)
I'd like to know too. If there is a machine where you can fit on a 1000 Grit paper or something
Old Oct 20, 2006 | 11:31 AM
baozer's Avatar
bump
Old Oct 21, 2006 | 12:21 PM
baozer's Avatar
up
Old Oct 21, 2006 | 03:50 PM
IdontKnowAnyPainters's Avatar
Default Re: anyone have any pointers for sanding? (mrtrinh)
ok... you have a stock already painted spoiler. i assume it has clearcoat on it. I would need to know if you were going to re clear it. if soo i would use 320 grit dry sandpaper. and then come back with like a 600 or 800 wet sand paper. do like 2 or 3 coats of base color then clear. wait like 4 min between base coats then when you clear wait about 10 between coats.
Old Oct 22, 2006 | 12:18 AM
baozer's Avatar
Default Re: anyone have any pointers for sanding? (KicksLikeEnergyDrink)
thanks man
Old Oct 22, 2006 | 06:11 AM
dowdle's Avatar
use wet sand sand paper dip the sand paper in water when ever it drys after using it wet it again and keep sanding
Old Oct 22, 2006 | 08:03 AM
delsoljesse's Avatar
you can use 400 wet or dry spray as many coats of base as it takes to cover or match ur color, letting it flash between coast, about 5-10 mins. then spray ur clear about 2 coats letting it flash 8-20 mins between coats
Old Oct 22, 2006 | 09:17 AM
pinoyboiwonder's Avatar
sand at a 90 degree angle.
Old Oct 22, 2006 | 02:16 PM
baozer's Avatar
ok so i just wet sanded and primered the spoiler.. its dry right now so do i wet sand again? i'm about to use 1000 grit.. and after that trim paint.. after i trim paint should i clear coat it too? my car is currently purple.. and i have black trim paint.. my current spoiler is black as well so i was just trying to make this spoiler look oem black.
Old Oct 22, 2006 | 02:25 PM
baozer's Avatar
up
Old Oct 25, 2006 | 07:34 PM
Default Re: (baozer)
yes after the primer is dry wet sand again with like 800 keeping the scratches not to deep. black is pretty easy to cover scratches with though. spray about 3 coats. yes i would clear because black will fade from sun aswell as when wasing the car
Old Oct 29, 2006 | 11:01 AM
baozer's Avatar
thanks.. i'll make sure to do so
zccrx
Mar 24, 2006 08:39 AM
f22 lx
Jun 2, 2005 04:53 PM
1.8
Nov 28, 2004 11:24 AM
Mai_CL-S
Sep 12, 2002 04:27 AM
