Portflow B-Series VTEC Inner Valve Springs
Old Oct 20, 2006 | 06:55 AM
kantfadedisazn's Avatar
Default Portflow B-Series VTEC Inner Valve Springs
has anybody had any experiance with these Portflow B-Series VTEC Inner Valve Springs? i have a jdm b16a would these springs be better than my stock ones
Old Oct 20, 2006 | 06:58 AM
crxnj's Avatar
Default Re: Portflow B-Series VTEC Inner Valve Springs (kantfadedisazn)
what kind of cams you got?
Old Oct 20, 2006 | 07:03 AM
Default Re: Portflow B-Series VTEC Inner Valve Springs (Mr.speaker)
i will be running sk2 s2s2 and toda cam gears
Old Oct 20, 2006 | 07:18 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kantfadedisazn &raquo;</TD></TR><TR><TD CLASS="quote">i will be running sk2 s2s2 and toda cam gears</TD></TR></TABLE>
ok,,you'll need upgraded springs for sure. You might as well get the whole spring and retainer kit,i think it's about ~$300 from portflow.
To answer your original question,yes these springs are better then stock when using such cams.
Old Oct 21, 2006 | 06:06 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">
To answer your original question,yes these springs are better then stock when using such cams.</TD></TR></TABLE>
hmmm i c even if i dont plan on going past 8k rpm?
Old Oct 21, 2006 | 09:13 PM
slowcivic2k's Avatar
portflows inner and the itr outer spring is good for 10,000 rpm with a max lift of 14mm, which is badass for just an inner upgrade, and interference retainers.
Old Oct 22, 2006 | 02:10 AM
crxnj's Avatar
Default Re: Portflow B-Series VTEC Inner Valve Springs (slowcivic2k)
hmmm i c even if i dont plan on going past 8k rpm?</TD></TR></TABLE>
it doesnt matter the cams have to high of a lift for stock springs
kantfadedisazn
18
Oct 26, 2006 02:17 PM
lilredhatch
16
Jun 10, 2004 07:53 PM
teg92
Feb 24, 2004 07:16 AM
