Parting out H23A EF Civic Hatch (Quaife LSD, H22, Hytech, EMS, Volk, Crower, Prelude, BB4, BB6)
A fair amount of the parts are sold, but still some good stuff like the EFH1 mounts, Rywire harness, Griffin radiator, Volk wheels, custom exhaust, & shift linkage.
ARP Head studs- $50
Resistor box- $20
Knock sensor (obd1)- $50
Vision catch can- $50
MSD SCI ignition with Blaster SS coil- $150
Rywire Harness H22/EF engine Harness & obd0-obd1 ECU harness- $200
H22 OBD1 external coil dizzy w/ plug wires- $80
Starter- $20
H series Alternator- $25
D series Alternator- $20
Crank Pulley Tool- $35
Custom 2 1/2” resonated exhaust for EF's w/ only 4-15° bends (sounds great, deep) w/ Thermal muffler- $250
Griffin Radiator EG half radiator (with slim fan)- $200
Hasport motor mounts- $375
Transmission:
Forbidden Short Shifter & Prelude shift linkage- $175
Fidanza 8lb flywheel (it's used)- $80
Suspension:
Explicit Speed front strut tower bar- $75
ST Front Sway bar- $100
Progress rear sway bar (2000 miles, you will need $43 of parts from Progress)- $50
Interior:
EF/ CRX Momo hub- $60
Exterior:
Volk Group C 15” with 215/45 Falken Azenis RT615 (1000miles on tires, wheels are 8.5/10)- $800
Volk/Rays GRN's with CEAT Tornadoes (tires nearly new, wheels are 7/10 due to paint imperfect)- $750
Rays lug nuts (set of 20 standard length, black)- $75
Fiber Images carbon fiber hood w/ hood pins (2 months old, like new)- $450/obo
Complete AC system (except the AC harness)- $75
Located in Utah
Sold items:
DSM 390cc injectors
Walbro fuel pump
Rays lug nuts
Aeromotive fuel filter, w/ braided lines
Intermediate shaft
Blacktrax Stage 4 ported intake manifold
STR 68mm throttle-body
Explicit Speed traction bar
AEM EMS (Obd1 #30-1040)
90-91 Si cluster
Taillights
Stage 2 clutches (2, both used)
Unorthodox Ultra R Crank pulley
Euro H23A block w/ H23 manual tensioner conversion & balance shafts removed
Moroso Oil pan
AEM fuel Rail w/ Marshall fuel pressure gauge
Hytech Header & Catco 2 1/2” cat
Password JDM rear strut tower bar
Greddy timing belt
Ported H22 head by Blacktrax, rockers balanced,Crower valvetrain (springs & retainers), Supertech Flat valves, 5 angle valve job
PLX M-300 wideband
STR Cam gears
M2A4 transmission w/ Quaife LSD, Gearspeed carbon synchros, & a new 1-2 sleeve
11” front Fastbrakes/Wilwood kit & 11” Fastbrakes rear drum to disc conversion [i]Modified by
Crower stage 3 cams
Hasport/DSS Stage 2 axles
Modified by 2lude4u at 1:52 PM 12/18/2006
ARP Head studs- $50
Resistor box- $20
Starter- $20
Transmission:
Suspension:
Interior:
Exterior:
Located in Utah
Sold items:
DSM 390cc injectors
Walbro fuel pump
Rays lug nuts
Intermediate shaft
90-91 Si cluster
Taillights
Moroso Oil pan
Greddy timing belt
PLX M-300 wideband
STR Cam gears
Crower stage 3 cams
lmk what you're interested in, shipping isn't too expensive depending on the items. However, I will be in SoCal in 2 weeks & could bring stuff down.
If you could find out how much for shipping for the fuel rail and pressure guage, cam gears, crank pulley, and the head if you can give me a packaged deal.
