ITR brakes on 96 Civic DX witch brake lines?
Old Oct 20, 2006 | 05:36 AM
Bullitt's Avatar
Default ITR brakes on 96 Civic DX witch brake lines?
I have a 96 DX Hatchback with the 9,5" (240mm) rotors at the front. I´m about to upgrade to ITR brakes with 11" rotors.
Can I use my stock DX brake lines?
Help me out. There are only a few guys in Germany how have done this conversion. And I don´t know who to ask.
Another thig: can I use the ITR 1" master cylinder on a non ABS car?
Old Oct 20, 2006 | 05:43 AM
philosofy1's Avatar
Default Re: ITR brakes on 96 Civic DX witch brake lines? (Bullitt)
the front lines should work, not sure about the rear lines. i would think you will need the integras. as for the 1" M/C, yes you can add it into the your civic, but will have to add the booster for it as well, and bend the brakes (hard) lines.
Old Oct 20, 2006 | 09:01 AM
Bullitt's Avatar
Default Re: ITR brakes on 96 Civic DX witch brake lines? (philosofy1)
This is all about the front brake lines. I have a working rear disc conversion.
I don´t thik that I have to change the brake booster. My Honda dealer told me that all brake boosters are the same. My brake bosster have the same part number as the EK4 VTi Civic. Only the master cylinders are different.
Old Oct 20, 2006 | 10:19 AM
BlueIntegraBoy's Avatar
You will need ITR front lines to be on the safe side.
Old Oct 20, 2006 | 12:02 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bullitt &raquo;</TD></TR><TR><TD CLASS="quote">This is all about the front brake lines. I have a working rear disc conversion.
I don´t thik that I have to change the brake booster. My Honda dealer told me that all brake boosters are the same. My brake bosster have the same part number as the EK4 VTi Civic. Only the master cylinders are different.</TD></TR></TABLE>
sorry, but i really don't know the specs on a EK4 VTi Civic. if the boosters are the same, then all you will need is to change the M/C. which will consist of bending the pipes to make it work.
Old Oct 20, 2006 | 12:30 PM
98+ 1" Integra MC will bolt up to the stock booster and you will not need to bend lines
Old Oct 21, 2006 | 08:22 AM
Bullitt's Avatar
Default Re: ITR brakes on 96 Civic DX witch brake lines? (BlueIntegraBoy)
Thanks for the replies
And you are sure about the brake lines, do i really need them? What is the difference between Civic DX and Integra lines.
Sorry, but I´m a noob in tech questions
Old Oct 21, 2006 | 08:25 AM
Bullitt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">98+ 1" Integra MC will bolt up to the stock booster and you will not need to bend lines</TD></TR></TABLE>
I have the 98+ brake booster. The Euro Integra was sold from 98 to 2000. So there are no other models available. Thats why they are so rare in Germany
ChangoLoco
May 6, 2013 08:42 AM
HypeRhino
Aug 14, 2011 03:25 PM
kgoner45
Jun 18, 2008 04:26 PM
92integraVTECgsr
Nov 7, 2005 09:15 PM
Project X
Oct 7, 2004 01:13 PM
