Suspension & Brakes Theory, alignment, spring rates....
KONI YELLOW KEEPS TURNING
Old Oct 19, 2006 | 10:26 PM
jlh22179tx's Avatar
Default KONI YELLOW KEEPS TURNING
i bought a 96 civic that came with some koni yellows. i tried to adjust it and i turn it both on one side so i know where am at. but one shock turns 2 revolutions more than the other side. does this mean that its broken? does koni warrenty this stuff?
Old Oct 20, 2006 | 02:15 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: KONI YELLOW KEEPS TURNING (jlh22179tx)
They are infinatly adjustable. Although I dont know which direction is soft, and with is hard.
Old Oct 20, 2006 | 07:29 AM
MoonScryer's Avatar
Default Re: KONI YELLOW KEEPS TURNING (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">They are infinatly adjustable. Although I dont know which direction is soft, and with is hard.</TD></TR></TABLE>
Actually, no they aren't adjustable like that. Koni yellows turn about 1 3/4 turn full soft to full hard. If you can go two turns, it means the valving inside is damaged and needs to be replaced.
Don't bother rebuilding it if its a stock or Neuspeed yellow, just buy a new one. A rebuild costs about $150-200.
Old Oct 20, 2006 | 08:42 AM
jlh22179tx's Avatar
Default Re: KONI YELLOW KEEPS TURNING (MoonScryer)
that probably explains why i press on that side it makes a sqeeky noise. not sure if i just want to replace the two fronts or just get a whole new coilover system.
i like the way it handles but its not very comfortable on the streets.
everyone hates on tein ss but i hear its good as far as comfortabilty
Old Oct 20, 2006 | 11:39 AM
the soL that could's Avatar
last time i spoke to CRX LEE... i remember him saying something about "if you can keep turning the adjusting ****, it's blown."
he'll be in here to verify. that guy is crazy information.
954K20z3
Honda Civic (2006 - 2015)
Jan 12, 2008 10:11 PM
JustAnotherRex
Suspension & Brakes
14
Nov 7, 2007 04:43 PM
johnzm
Suspension & Brakes
Feb 8, 2006 11:29 AM
be.twenty
Suspension & Brakes
Aug 2, 2005 10:25 AM
GreenGSR311
Sep 14, 2004 06:36 PM
