FS: Parting Front End 97+ Prelude: Dash, Engine Harness, Manual Swap Parts, etc
These are the only parts I have left from my 1997 Honda Prelude SH. The prices are OBO without shipping costs.
SH tranny - $350
Radio and Center Console Dash Piece - $30
Cluster Dash Piece – broken - $10
Drivers and Passengers door handle - $30
Brake Master Cylinder - $40
ABS Pump - $45
Power Steering Pump - $45
Misc brackets and parts
Modified by DC2-JRSC'd at 2:18 PM 2/6/2007
SH tranny - $350
ABS Pump - $45
Any of these still available? Lookin to do swap ASAP :-)
Transmission Assembly
Tranny mounts-side
Engine Mount-rear
Flywheel and bolts
Clutch Kit and bolts
Clutch Master Cylinder
Clutch Pedal Assembly
Brake Pedal Assembly
Shifter Assembly
Shift linkage
Manual ECU
Manual Intermediate shaft (half-shaft)
Manual Cluster (optional)
Cotter Pins (assorted sizes)
Tranny mounts-side
Engine Mount-rear
Flywheel and bolts
Shifter Assembly
Shift linkage
Manual ECU
I need the hub and bearing assembly for both sides. Do you have them and how much? Give me a call at 618 889-3298. I need them to install the drive shaft shop axels that I bought for my 93 lude. Please give me a call so that I can get them soon. Thanks Daniel
Wondering if you might have removed/kept the immobilizer key/ring around the ignition, the receiving unit, and the ecu?
