why do 205 15s rub?? :(
Old Oct 19, 2006 | 08:22 PM
Turbo_Mike's Avatar
Default why do 205 15s rub?? :(
I just bought some 15" slips with 205 50 azenis and they are rubbing I'm lowered on h&r springs , so its not even a 2" drop. WTF Now i'm rubbing like a bitch in the back?
I thought a lot of u guys were running 205s?
Old Oct 19, 2006 | 08:30 PM
.Manny.'s Avatar
Touching My Member
Default Re: why do 205 15s rub?? :( (Turbo_Mike)
doesnt the offset of the wheel affect that too? what is the offset?
Old Oct 19, 2006 | 08:33 PM
thursday's Avatar
its probably rubbing on something in the inner fender well that can be easily cut or bent out of the way. I'm running 205/50/15 rotas (7" wide) on my 93 hatch and i had to bend a little tab up and out of the way in the back. Jack your car up and take a look.
Old Oct 19, 2006 | 08:58 PM
Turbo_Mike's Avatar
Default Re: (thursday)
Its rubbin the outer fender which was mint
Old Oct 19, 2006 | 09:15 PM
Deetz's Avatar
Crazy Honda Guy
Mine doesn't rub....get some higher offset rims
Old Oct 19, 2006 | 09:56 PM
Turbo_Mike's Avatar
Default Re: (Deetz)
not sure if these are +35 or 40, i gotta check tomorrow
Old Oct 20, 2006 | 04:26 AM
Autoworks's Avatar
Default Re: (Turbo_Mike)
It would have to be in the wheel offset. 205/50-15's usually don't rub at all. Mine did not rub when I had my slips, but the last hatch I built with slips did rub on the outside fender, same size tire, different offsets between the sets. His rubbing was minor.
Old Oct 20, 2006 | 04:29 AM
driveahonda's Avatar
I had this problem also. I just got stiffer struts so the fender didn't go down on the rim anymore.
Old Oct 20, 2006 | 05:50 AM
civiconfire's Avatar
its the off set
i had the same problem with my wheels... i just put 195's on ond its fine.
if you dont need new tires or cant afford them have your rear frnders rolled
Old Oct 20, 2006 | 06:30 AM
90civichbsi's Avatar
Default Re: (civiconfire)
i run +42 offset and i had to roll in the inner lip on my fender to stop rubbing.. if its a +40 or even +35 offset thats your problem
Old Oct 20, 2006 | 07:30 AM
Turbo_Mike's Avatar
Default Re: (90civichbsi)
yea the 15x7 only comes in one of those two sizes
do u guys roll ur fenders yourself? how do u do it? does it take off the paint /protective coating on the fender?
Old Oct 20, 2006 | 07:35 AM
andrey320's Avatar
I have GSR blades with 205/15s on my crx which is also lowered on H&R sport (1.75) springs. No rubbing at all... Must be the offset.
Old Oct 20, 2006 | 08:21 AM
Turbo_Mike's Avatar
Default Re: (andrey320)
Here's a pic of the 215 50s i bought for my last wheels. They rubbed just as bad so i had to sell them
Now these new wheels dont fit either , damnnit
Old Oct 20, 2006 | 08:57 AM
Chronicsinners's Avatar
Heres my rubbing experience:
My 15x6.5 +40 slips rubbed with 205/50/15 azenis. I also had DA rear brakes which apparently shimmed the rear of the car out a couple mm. What i did to solve the problem was just sell the wheels.
I also purchased a different set of wheels that rubbed, at this point i have had it with the rubbing issue so i broke down and bought a fender rolling tool. Shamesless plug: I will rent the fender rolling tool to anyone for 75$ a week plus deposit. PM me if you are interested.
EF's with meaty tires need a high offsets to clear the rears!
Old Oct 20, 2006 | 09:38 AM
Suck my DX's Avatar
Default Re: (Chronicsinners)
to OP, what is your suspension setup?
Old Oct 20, 2006 | 09:50 AM
Turbo_Mike's Avatar
Default Re: (Suck my DX)
h&r sports and tokico blues
Old Oct 20, 2006 | 11:51 AM
KingDanOne's Avatar
i suggest you roll your fenders, it looks like they are rubbing on the fenders... do it your self and just bend them up
Old Oct 20, 2006 | 12:09 PM
<FONT COLOR="red">I think the problem is definetly in your suspension. It must sag a lot when you are moving, causing your fenders to come down on your tires.
Mine look just like the picture you posted but I dont have the rubbing problem. You need better suspension.</FONT>
Old Oct 20, 2006 | 12:11 PM
88 rex's Avatar
Default Re: why do 205 15s rub?? :( (KingDanOne)
Wrong offset
And roll the fender, AND maybe add some camber back there.
Old Oct 20, 2006 | 12:34 PM
Suck my DX's Avatar
Default Re: why do 205 15s rub?? :( (88 rex)
rolling the fenders will help, but those tokikos are whats really causin em to rub
Old Oct 20, 2006 | 12:40 PM
Furyof4's Avatar
6.5" circuit 8's +38 offset, azenis--&gt; rubbed with anything less than 2 deg of
camber f&r
7" rpf1 +41 offset, azenis--&gt; no rubbing with 1 deg camber rear
Rear camber and offset play a big role. Also remember that azenis are wider than most 205's.
Old Oct 20, 2006 | 12:46 PM
KingDanOne's Avatar
Default Re: why do 205 15s rub?? :( (Furyof4)
my car is llike a half inch lower than yours and it doesnt rub...
Old Oct 20, 2006 | 01:03 PM
andrey320's Avatar
My setup is pretty much like the op's. The only difference being the wheel type and shock type (and maybe camber - I don't have a camber kit). My shocks and springs are about 18 months old.
Old Oct 20, 2006 | 02:40 PM
B6tizzleHatch's Avatar
SAME PROBLEM! i have 15 x 6.5 rota group n's with 205 50 15 azenis 615s on there
my front rubs.... tokico illuminas w/progress springs. i put coilover sleeves on them so i can adjust it!
Old Oct 20, 2006 | 03:24 PM
1989CivicSi's Avatar
Default Re: (B6tizzleHatch)
Looks like an offset problem. With my Spun Supermesh and 205/50/15 Kumho AST's I only had rubbing problems on the passenger's side rear quarter due to rust replacement sometime in its life and the bodyshop guy not welding the quarter out far enough.
Also, I'm running H&R sports + Tokico 5 way illumina's without rubbing issues on the other 3 corners...just the one that was once replaced (need to get it rolled out).
