2001 f4i steering damper install help
Old Oct 19, 2006 | 08:18 PM
built562's Avatar
Default 2001 f4i steering damper install help
so i got a good deal on a brand new shindy datytona damper on ebay.
i installed it tonight and the unit it self feels loose. the actual shock body rocks back and forth a little bit. the steering is still free and i followed the directions but i was wondering if anyone has ever used this brand before.
i will post pics and maybe a small mpeg to show what i mean if my crappy description doent help.
Old Oct 19, 2006 | 08:23 PM
marmaladedad's Avatar
Uhhh, it's eBay. It could be crap.
Did you try adjusting it to full-stiff? (and yes, it does rock a bit)
Old Oct 20, 2006 | 05:23 AM
built562's Avatar
Default Re: (marmaladeboy)
its not that its ebay, the damper is available online every where for much high prices. its not ebay junk.
yeah its rocking side to side a little, so this might be normal?
Old Oct 20, 2006 | 06:10 AM
backlash's Avatar
Default Re: (built562)
Like the damper is moving/shaking in the mounting brackets? Put up that video, that might help. If the whole damper is moving, maybe you got the wrong mounting brackets???
Old Oct 20, 2006 | 07:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built562 &raquo;</TD></TR><TR><TD CLASS="quote">its not that its ebay, the damper is available online every where for much high prices. its not ebay junk.
yeah its rocking side to side a little, so this might be normal?</TD></TR></TABLE>
I did not mean it was a "generic, no-name" damper, but that it was someone's junk from eBay. No offense was meant.
My damper on the GSXR could "rotate," or shift a little bit, around the ball that was part of the bolt that connected the damper to the damper-bung hole.
Can you post two pictures of the damper? One of it in its 'normal' position, and one where it is 'abnormal.'
Old Oct 20, 2006 | 01:58 PM
ngng's Avatar
my ohlins would wobble
JDMEDWIN1904
May 25, 2008 09:26 AM
aaronISthrowed
Jan 12, 2008 01:20 PM
projectef
May 2, 2007 04:56 PM
xelloss
Oct 15, 2006 07:53 AM
scheistermeister
Feb 19, 2006 10:51 AM
