Resurfacing/repairing JUN chromoly flywheel
How much does it cost to resurface a chromoly steel flywheel? and Where is the best place to take it around the SF bay area?
Also How much and where to get this repaired?
NOT MY PICS, So I am not sure how that happened. I am trying to see if its worth it to purchase and get repaired?
Any good machine shop should be able to resurface it.
It looks like some type of flaking where the bolts go?
How much is it anyways, Low enough to be worth the small amount of work?
Yes, resurfacing(turning) the flywheel should be a common machine shop job, I would think. I would like to know how much it should cost to do the work and where people in the Bay Area would recommend I take it to.
If the cost to repair is cheap enough I might consider picking this up. The seller has not responded yet to questions I asked about the damage around the bolt area.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE »</TD></TR><TR><TD CLASS="quote">i paid 40 to have my flywheel surfaced. i wouldnt bother with that flywheel tho. having the area that bolts to the crank fixed would prolly cost a bit.</TD></TR></TABLE>
Some are saying that it can be fixed under $100, and some say not to bother with it. I cant get a decent quote from any machine shop Ive talked to (they say they will need to see the actual part, which I totally understand) I might just skip this as I cant get a solid quote on it.
Too bad, its a good chromoly flywheel, designed/lightened the right way. (weight is reduced on the outside ring of the flywheel, leaving the center with the weight; unlike aluminum ones where the weight is reduced on the whole flywheel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm »</TD></TR><TR><TD CLASS="quote">
How much is it anyways, Low enough to be worth the small amount of work?</TD></TR></TABLE>
Not sure what the starting bid was, but it could be found on thE bay.
http://cgi.ebay.com/ebaymotors...d=1,1
nb0
Sep 6, 2009 01:48 AM
hondura
Oct 23, 2006 05:57 PM
Calvinator
Oct 7, 2004 10:48 AM
