H22 Axles in Ef, How To?
Old Oct 19, 2006 | 05:17 PM
eg360B's Avatar
Default H22 Axles in Ef, How To?
I have a friend that put a H22 in a Ef and needs axles. He doesnt want to buy aftermarket ones so he is trying to make is own using honda parts. Someone told him using 90-93 Integra Outers and Accord Inners but the Accords Inners are to long. Does anyone know if you can even use different parts to make Axles work for a H22? please need some Help and Info.
I tried Searching H22 Ef Axles, h22 Civic Axles and didnt find anything.
Old Oct 19, 2006 | 05:18 PM
philkehn's Avatar
h22 axles wont bolt up to your rotors, you need to get h22 rotors..
Old Oct 19, 2006 | 05:20 PM
eg360B's Avatar
Default Re: (philkehn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philkehn &raquo;</TD></TR><TR><TD CLASS="quote">h22 axles wont bolt up to your rotors, you need to get h22 rotors..</TD></TR></TABLE>
Yes I know thats why someone told him to use Interga Outers. So basically you cant make some?
Old Oct 19, 2006 | 05:29 PM
philkehn's Avatar
I think you can cut them and reweld, but im not a welder so i dont know how hard it would be
Old Oct 19, 2006 | 05:36 PM
lightcrx's Avatar
use 90-93 teg axels and prelue inners, if the passenger side is too long get a 89 teg axel
hope that makes sense
Old Oct 26, 2006 | 05:16 PM
90h22ef's Avatar
Default Re: H22 Axles in Ef, How To? (Byrd Gang 021)
the 90-93 integra axels will work, but if u launch it couple of times they will probably break. and also i just bought a 90 hatch with jdm h22a , the car will idle fine but as soon as i step on the throttle it will shut off. can any one help me out.
Old Oct 26, 2006 | 05:45 PM
lightcrx's Avatar
Default Re: H22 Axles in Ef, How To? (90h22ef)
timing? got any cel's?
Old Oct 26, 2006 | 08:57 PM
Contender25
Guest
Posts: n/a
Yeah like most swaps in the EF/ED, 90-93 non ABS, 5 spd only integra axles will work, but you might be cuttin it on thin ice usin those with the beefy h22.
JasinS
10
Dec 26, 2007 08:32 PM
cccya
Apr 25, 2002 04:19 PM
