need help motor idles high
Old Oct 19, 2006 | 04:13 PM
DB8-teggy's Avatar
Default need help motor idles high
ok its a 96 integra gsr with 95 gsr motor, ok so the problem is when u start the car it idles lil over 2g, and it drops to around 1500 1800 when it gets warm, also it takes a while to for temp gauge to start raising. also when i got the car the ecu plugs where cut and i rewired it up all the colors matched but it had a couple of wires that were identical. any help is thanked
Old Oct 20, 2006 | 05:36 AM
gmboogy's Avatar
Default Re: need help motor idles high (DB8-teggy)
it's because of the cold temp outside. mine does the same.
Old Oct 20, 2006 | 05:51 AM
99DCteG's Avatar
yea, mine idles high when i first start er up too.
Old Oct 20, 2006 | 06:29 AM
TurbodTegSfaria's Avatar
Default Re: (integras_are_best)
check for vacuum leaks and coolant if its abnormal
Old Oct 21, 2006 | 07:58 PM
DB8-teggy's Avatar
it always idles high it never drops down to normal idle it could be hot outside. coolant is good, could it be that one of the ecu wires that i connected are mixed up does any one have wut each wire is for from the ecu to car thanks
Old Oct 21, 2006 | 08:33 PM
colored's Avatar
hey you said that the idle drops to 1500-1800 when it gets warm, yeah thats what it always does. i have a 2000 gsr and it always idles high like 2000 when i first start it, then it comes right back down.
SmogKing's Avatar
Default Re: (DB8-teggy)
Check 4 vacuum leaks, a vacuum leak will cause high idle. If you had the wires wired up wrong you should get a CEL(code).
Old Oct 21, 2006 | 09:03 PM
DB8-teggy's Avatar
yea it drops to around there but it dosent go lower to normal also it does have a cel but idot have a 02 sensor but that wouldn cause the idle to be high also u know that emission canister on the left near the axle in the engine bay i dont have that not really nesassary is it.
jkalex05
Dec 6, 2009 01:54 AM
H22ARunninHard
Aug 14, 2007 01:33 PM
91dxhatch
Jan 4, 2007 11:46 AM
jdmeg94hatch
Apr 5, 2006 05:38 PM
KoRE
Jun 11, 2002 05:40 PM
