super owned, front and rear wheels both bent :/ man no money for new ones, am i ok?
well my front and rear wheels are bent, one of my co workers noticed it he noticed the rear so when i checked the front yup JUST MY ******* LUCK that ones bent to.
i dont have money cuase money is tight right now, ive probably been riding on these forever im pretty sure it happen awhile back while in the twisties, i feel no wobble at all really, wondering if its fine riding like this? when i get money i'll fix it both bends are on the right side.
checked the tire psi the rear holds 30 forgot to check the front but the front has a less of a bend....bah the rear is a little bit big, sigh dindt even check the forks...what do i look for? exactly? just see if there strait?
No leaks on the forks? With the rear of the bike on a stable stand, compress the front end. Does it go down smoothly, or does it feel hard to do? The friction could also be due to old components in your forks. It's not hard to remove the front wheel and take off the forks (you'll need a front stand that lifts from the triple) and check each fork.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red91sit »</TD></TR><TR><TD CLASS="quote">I've been riding with a bent front fork, the only problems I've noticed is a scary shaking on right hand corners, and my left arm gets much sorer after long drives.</TD></TR></TABLE>
steronz
Dec 20, 2010 06:44 PM
