Cleaning out garage crx stuff integra axels shift linkage
Make offers
FS: autometer oil pressure electrical sender unit only no gauge
FS: ZC oil cooler with center bolt
FS: brand new 88-91 crx shift boot
FS: 88-91 crx si front mud flaps
FS: 88-91 JDM crx fuse box inside of engine bay
FS: 88-91 crx splash gaurd I believe its driver side says L on it
FS: 88-91 crx starter from autozone low mileage
FS: 88-91 crx si driver and passenger side axels.
FS: 88 crx si motor mounts and brackets
FS: 88-91 crx si front upper shock hats
FS: 88-91 crx si upper and lower heat shield
FS: 88 crx si front suspension fork
FS: 88 crx si big metal ecu cover
FS: 88-91 crx stock d series header upper portion 4-2-1
FS: 88 crx si cluster cover
FS: 88 crx si defrost button
FS: 90-91 crx si cluster cover
FS: 90-91 crx si hazard switch button
FS: 88 crx si dimmer switch
FS: 88 crx fuse panel cover inside of car
FS: 88 crx main relay
FS: 88 crx si upper timing belt cover
FS: 88 crx si blower the one under the dash
FS: 88 crx si driver side engine bracket timing belt side
FS: 88 crx rear tranny bracket
FS: 88 crx rear view mirror
FS: 2 88 crx si fuel rails
FS: 88 crx si clock
FS: 88 crx si map sensor and two other tiny canisters sensors related to smog
FS: 4 1g b16a injectors
FS: 4 b16a rods
FS: b16a throttle body minus tps sensor
FS: b16a engine block water coolant pipe and peice that holds the thermostat
FS: b16a intake and exhaust cams with gears
FS: b16a main bearing caps with bolts
FS: 1g b16a intake manifold complete with injectors, fuel rail, and throttle body
FS: 1g b16a downpipe and upper portion of header
FS: b16a used water pump
FS: 1g b16a fuel rail
FS: 95 GSR fuel pressure regulator
FS: 86-89 integra ZC oil pan
FS: 86-87 integra ZC valve says HONDA on it in big letters painted blue
FS: 95 LS driver side engine bracket timing belt side
FS: 1g b16a engine bracket timing belt side
FS: 95 Ls alternator brackets
FS: 94+GSR upper engine mount driver side and bracket
FS: 94+ gsr axels new
FS: 1g b16a lower timing belt cover and inner timming belt cover
FS: LS pistons
FS: 94 integra shift linkage with short shifter included
FS: 94 integra mounts
FS: obd 1 civic fuel injectors clips
FS: carsound cat used 3000 miles 2.25" 14 inch long with flange flared to fit the JDM 4-1 type R header with both heat shields barely used
FS: LS pistons
email me at lbradtech@yahoo.com with any questions or PM me
Modified by JohnnyEF at 11:55 PM 12/1/2006
FS: 88 crx si clock
FS: 4 b16a rods
FS: LS pistons
FS: LS pistons
