WILL THE SI-R GAUGES WORK ON MY CAR??
Old Oct 19, 2006 | 03:06 PM
EFHATCH88's Avatar
Default WILL THE SI-R GAUGES WORK ON MY CAR??
I GOT A 91 CIVIC HATCH WITH A B16A SWAP IN IT AND I STILL GOT MY STOCK GAUGES, I FOUND THE JDM SI-R GAUGES FOR A PRETTY GOOD PRICE..I WANT TO KNOW WILL IT HOOK UP TO MY WIRES NO PROBLEM OR WILL I HAVE TO MODIFY ANYTHING BECAUSE I NOTICED SOME OF THE PLUGS LOOK A LITTLE DIFFERENT THEN WAT I HAVE ON MY CAR
HERE SOME PICS OF THE GAUGES I WANT TO PUT ON
Old Oct 19, 2006 | 03:16 PM
doublethink's Avatar
Default Re: WILL THE SI-R GAUGES WORK ON MY CAR?? (EFHATCH88)
it works as long as you have an electronis VSS on the motor itself.
as far as wire hookups, look in the FAQ on top of the forum. theres a chart to wire it up.
its easy ive done them before, the only tricky part is running the wire for the VSS signal.
since all USDM 88-91 civics are cable driven speedos, you wont be using the cable anymore, a single wire replaces it.
since im bored:
SiR Cluster Wiring:
http://b16a.honda-perf.org/cluster.html
stemiched
Jun 7, 2006 11:14 AM
pulse_crx
May 16, 2005 04:58 PM
hatchii
10
Aug 8, 2004 10:41 PM
