jdm H22A fidanza 8lb flywheel
Whats up guys, I have a quick question. I recived my fidanza 8lb flywheel for my 94 h22. My question is the flywheel i recieved has a pilot bearing already installed in it. All the obd1 h22 flywheels I've seen never had a pilot bearing. Can I still use this? Or should I removed the bearing? Or should I send it back and get the right one? I don't have the old flywheel to compare it to either. Thanks-Eric
Well my Fidanza came with a pilot bearing installed. And at importhorizons the 92-01 preludes all have the same item number. So i would guess the flywheel comes with the pilot bearing for all H22s.
I also noticed you guys are all running newer h22a's. There has to be a reason why the older accords/ludes don't have a pilot bearing in the stock flywheel.
