Built motor and SMog
Old Oct 19, 2006 | 11:22 AM
gtz's Avatar
gtz
Default Built motor and SMog
hey guys im not sure where to post this so hopefully it isnt put of place here.
How many of you pass smog test with a built motor? Is it possible? i have a b16 that im gonna rebuild but im not sure what will pass smog in 2 years. i could build it for boost and lower the compression to 9:1 but when i take the turbo stuff off my car for the sniffer test will it pass? OR i could get higher compression pistons, p & p, cams, all that good stuff to get me around 200whp. but when i go to the State Ref to get the motor Bar'd will i fail the sniffer portion on the stock p2t ecu? im leaning toward the bottom end build with lower compression but im afraid the ref will fail me cause i cant pass the sniffer
anyone have a similar experience?
Old Oct 19, 2006 | 05:18 PM
b16civster's Avatar
Default Re: Built motor and SMog (gtz)
you could pass it either way (w/ or w/o turbo) if you tune it for each
Old Oct 19, 2006 | 05:44 PM
itralex's Avatar
Default Re: Built motor and SMog (b16civster)
I passed the sniffer test with my car up here in Canada
i have 13.0cr 2.0L motor with RM M22x cams, however to get it to pass the whole car had to get retuned for the sniffer portion
Old Oct 19, 2006 | 07:57 PM
SkankyEJ7's Avatar
Default Re: Built motor and SMog (itralex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itralex &raquo;</TD></TR><TR><TD CLASS="quote">however to get it to pass the whole car had to get retuned for the sniffer portion</TD></TR></TABLE>
so you had to tune it so it that it would pass.
Old Oct 19, 2006 | 09:07 PM
gtz's Avatar
gtz
cool. i just get a tune for the sniffer and ill be good. what are the chances of it getting Bard with lower compression and the stock ecu? will the ecu adjust?
Old Oct 20, 2006 | 10:18 AM
TEST ONLY's Avatar
Default Re: Built motor and SMog (SkankyEJ7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkankyEJ7 &raquo;</TD></TR><TR><TD CLASS="quote">
so you had to tune it so it that it would pass. </TD></TR></TABLE>
Any car can LEGALLY pass smog with any turbo or engine swap.....
Old Oct 20, 2006 | 11:11 AM
91SiZ6's Avatar
Default Re: Built motor and SMog (hazw8st)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hazw8st &raquo;</TD></TR><TR><TD CLASS="quote">Any car can LEGALLY pass smog with any turbo or engine swap.....</TD></TR></TABLE>
Too bad that isn't true.
Old Oct 20, 2006 | 12:04 PM
strsi's Avatar
Default Re: Built motor and SMog (91SiZ6)
it is if u contact hazw8st. he took care of me. my car is now smog exempt in CA.
Old Oct 20, 2006 | 12:55 PM
Smoggy8's Avatar
I could help u with ur smog.
Old Oct 20, 2006 | 01:42 PM
B16b-EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SiZ6 &raquo;</TD></TR><TR><TD CLASS="quote">
Too bad that isn't true.</TD></TR></TABLE>
Idiot...contact hazw8st!
Old Oct 20, 2006 | 04:22 PM
TEST ONLY's Avatar
Default Re: Built motor and SMog (B16b-EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smoggy8 &raquo;</TD></TR><TR><TD CLASS="quote">I could help u with ur smog.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Idiot...contact hazw8st!</TD></TR></TABLE>
Really? Why?
Old Nov 27, 2006 | 03:59 PM
hbcrazy's Avatar
What?
Old Nov 27, 2006 | 09:29 PM
dude_123's Avatar
Default Re: Built motor and SMog (hbcrazy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> Any car can LEGALLY pass smog with any turbo or engine swap....[QUOTE]
[QUOTE=hbcrazy]What?</TD></TR></TABLE>
Sounds crazy but true, I didn't believe so until I saw my friend's hatch with a ls swap with a custom turbo kit that had BAR stickers for the swap and the turbo kit. The turbo kit is a custom log manifold with external wastegate, the turbo is a funky looking t3/t4 hybrid turbo. I mean funky because I have not seen a .48ar hot side with a .80ar cold side turbo before.
Old Nov 28, 2006 | 02:36 PM
B16b-EJ8's Avatar
Default Re: Built motor and SMog (dude_123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dude_123 &raquo;</TD></TR><TR><TD CLASS="quote">
Sounds crazy but true, I didn't believe so until I saw my friend's hatch with a ls swap with a custom turbo kit that had BAR stickers for the swap and the turbo kit. The turbo kit is a custom log manifold with external wastegate, the turbo is a funky looking t3/t4 hybrid turbo. I mean funky because I have not seen a .48ar hot side with a .80ar cold side turbo before.</TD></TR></TABLE>
Did he go to hazw8st?
Old Nov 28, 2006 | 05:51 PM
hbcrazy's Avatar
Default Re: Built motor and SMog (strsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strsi &raquo;</TD></TR><TR><TD CLASS="quote">it is if u contact hazw8st. he took care of me. my car is now smog exempt in CA.</TD></TR></TABLE>
How does smog exemption work in CA? wtf? Never heard of this, is it fo real???
Old Dec 3, 2006 | 08:13 AM
MAV3RiCK478's Avatar
if your car is registered in a county that doesn't require smog, like here in north bay area you register your car in occidental or lake county.
Old Dec 3, 2006 | 08:19 AM
Boots's Avatar
Default Re: Built motor and SMog (MAV3RiCK478)
wow im kinda glad i dont own a car in cali...we dont even know what the hell smog is here in VA
Old Dec 3, 2006 | 12:57 PM
91SiZ6's Avatar
First, B16B-EJ8. You can eat a dick. Idiot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hazw8st &raquo;</TD></TR><TR><TD CLASS="quote">Really? Why?</TD></TR></TABLE>
I posted that before reading other posts about what you do. I still don't quite get how you make parts that don't have CARB EO#s smog legal, but it's cool that you can. Not worth it to me to be John Force on the street, but cool none-the-less.
Old Dec 3, 2006 | 06:29 PM
TEST ONLY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SiZ6 &raquo;</TD></TR><TR><TD CLASS="quote">First, B16B-EJ8. You can eat a dick. Idiot.</TD></TR></TABLE>
Interesting choice of words....
Old Dec 3, 2006 | 06:38 PM
AllMTRWH0R3's Avatar
^^^^^ Hazw8st be me too it! Jay is kind of in the business of sit down, buckle up, hold on and shut up
Old Dec 3, 2006 | 06:52 PM
TEST ONLY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hbcrazy &raquo;</TD></TR><TR><TD CLASS="quote">How does smog exemption work in CA? wtf? Never heard of this, is it fo real??? </TD></TR></TABLE>
Yes.
Old Dec 4, 2006 | 07:16 AM
GEIJIN's Avatar
better have a smog hook up haha. i'm getting a ej1 with a jdm b18c1 swap with itr cams and a few other goodies and i'm not even thinking about going through the hassles and putting everything back to stock. Pay the $$$$$$$$$$ and get no hassle brotha!
Old Dec 4, 2006 | 07:57 AM
AMS MIKE's Avatar
wrong words to say to someone who COULD have helped you.
your loss.
Old Dec 4, 2006 | 08:33 AM
b19coupe's Avatar
What if an OBD2 car has been converted to OBD1? How does it get past the OBD2 scannning part of the ASM testing?
Old Dec 4, 2006 | 02:10 PM
91SiZ6's Avatar
Default Re: Built motor and SMog (AMS MIKE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMS MIKE &raquo;</TD></TR><TR><TD CLASS="quote">wrong words to say to someone who COULD have helped you.
your loss.</TD></TR></TABLE>
Yes, it's my loss. I'm sure there's nobody else on this entire forum capable of answering questions is a less bullshit manner. When your first word in a reply to someone is "idiot", you're an internet tool. This site is actually full of internet tools who wouldn't mouth off half as much in real life as they do here. I follow the golden rule, treat me like **** and I'll be more than happy to return the favor...with interest. Treat me with respect and I'll show you unlimited respect in return. It's a two way street.
