L. Control arm and rear knuckle problems
So, I took my car to get an alignment and found out that my Right Front Lower Control Arm is bent very badly and my Right Rear Knuckle is in really bad shape to... hmm... the total for these two parts installed and for the lifetime alignment total pricing is $649.83!!! That sound's about right I guess... I just wanted to know if I can use a used LCA, but I don't know where it's located... plus is it hard to take it out, I have another 94 accord junk lyin' around, so I just wanted to use that accord's LCA and I was wonderin' if I could also use the Right Rear Knuckle off the same accord... Thanks
Cliff notes:
- Right Front Lower Control Arm and Right Rear Knuckle is in bad condition
- Will 94 Accord w/ same parts fit?
- Where is it and is it easy to take off? Pics will help out ALOT!!! thanks!
Cliff notes:
dude save yourself bout 500 bucks and do it yourself the front lower control arm is in the front lower control arm look at the lower part or the assembly there is an arm that bolt to the bottom of the hub and then connect to the frame if you have the tools it will be possible to do it the rear knuckle cant help you on that one never did one sorry
AZ-Accord
Jan 9, 2013 05:23 PM
nhaltezza
Jan 17, 2011 10:07 AM
MaXiMuS1701
Jun 29, 2007 10:12 PM
