For those of you with ZC's
Old Oct 19, 2006 | 10:34 AM
Spoon 722's Avatar
Default For those of you with ZC's
Alright I am about to buy a 90 CRX with a DOHC ZC in it. What I need to know is what bottom block in america can I get bearings for it because the previous owner spun them Other then that everything is decent.
Old Oct 19, 2006 | 10:48 AM
jays93eg6's Avatar
Default Re: For those of you with ZC's (Spoon 722)
I believe it to be the D16A1. It came in the 1st Gen Integras. I think the model years were 1986-1989. Hope this helps.
Old Oct 19, 2006 | 10:50 AM
wiZCo's Avatar
Stouts 'n' Scotch
Check out http://www.thezcr.com, all the ZC info you'll ever need is right there. For your rod bearings, just get them for a same year Civic/CRX Si (the year of the motor will be stamped between the #2 and #3 exhaust ports).
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: For those of you with ZC's (jays93eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jays93eg6 &raquo;</TD></TR><TR><TD CLASS="quote">I believe it to be the D16A1. It came in the 1st Gen Integras. I think the model years were 1986-1989. Hope this helps.</TD></TR></TABLE>
Common misconception, these motors were similar, but not the same. Get ones from a Civic/CRX .
Old Oct 19, 2006 | 10:52 AM
Spoon 722's Avatar
Thanks for the info guys, I was thinking maybe the Si bearings would be the closest I just want to make sure I can get them easily before buying it.
jdm_jeners
Classic Hondas
Jun 20, 2007 02:14 PM
hybridmiklo
Oct 17, 2006 08:00 PM
hondaboy90
Mar 15, 2006 03:52 PM
SpankyofNOLA
Dec 29, 2004 09:05 AM
redrumracing
Aug 12, 2004 01:39 PM
