b16 head
Old Oct 19, 2006 | 10:10 AM
JdM_RACeR07's Avatar
Default b16 head
okay so i took apart my head in an attempt to remove the head from the block and i got 4 of the 10 screws off.....welllll it appears that the guy that had the motor b4 me stripped out the bolts and now i cant take off those last 6 does anyone know how i would go about removing those last 6 bolts???? i need them out asap cuz sum1 wants to buy my head for 350
thanks guys
JdM_RaCeR
Old Oct 19, 2006 | 10:19 AM
philkehn's Avatar
well if the bolts are stipped your head isnt worth 350 bucks, it might be the threads in the head? or are the just stuck, have you tried to use a cheater bar to get them out, the only way i know to get a stripped screw out is to drill it out...
Old Oct 19, 2006 | 10:21 AM
Suck my DX's Avatar
Default Re: (philkehn)
SUM BIG *** VICE GRIPS
Old Oct 19, 2006 | 10:25 AM
no the head is perfectly fine its just the head of the bolts that are stripped out i have extra bolts for heads so if i can get those last 6 off i would just give him the head with 6 different bolts rather then the stripped bolts
Old Oct 19, 2006 | 12:27 PM
baphomet's Avatar
Default Re: (JdM_RACeR07)
Sears (and most autoparts stores now) has a set of socket looking things that will grip on to the stripped heads. I think they are called 'bolt out' at sears. Get the cheaper generic ones though.
Bolt out
Saves my *** all the time.
Old Oct 19, 2006 | 12:43 PM
SinSeven's Avatar
Default Re: b16 head (JdM_RACeR07)
man this is a tough one. YOu could tap into the stock head bolts with a die set and then turn them out by drilling a slightly smaller screw. Just a suggestion.
wantboost
Apr 30, 2011 05:28 PM
tony7626
Apr 2, 2009 05:13 PM
xiaogou
Apr 7, 2007 12:47 PM
fukaintmuven
Mar 7, 2003 10:57 PM
