Why am I backfiring?
Old May 4, 2002 | 04:32 PM
Monarch's Avatar
Default Why am I backfiring?
okay, last week we installed a cat back Tanabe exhaust on my del sol, more than a week later it is STILL backfiring when i shift, i've noticed that it only does this sometimes and its always around the same RPM that it does it....
i have driven this car everyday, so i figured by now it should be used to the pipe size differance.. but i could be wrong...
help
Old May 4, 2002 | 04:37 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: Why am I backfiring? (grinched)
do you mean backpressure or stuff actually like comes out of the exhaust......either one i think this might help...mine does it only sometimes but it used to do it when i had a minor leak in my exhaust....like it wasnt tightened all the way when i did it. check out this sight...http://www.mgbexperience.com/service/tips/exhaust.html
Old May 4, 2002 | 06:59 PM
EVIL Hx Coupe's Avatar
Default Re: Why am I backfiring? (CiRcUiTsi)
Same thing happend to me and it was that i didn't have my exhaust tightened all the way.
Does it take times for cars to get used to exhausts???? I think not.
[Modified by Boost Pressure, 8:00 PM 5/4/2002]
Old May 4, 2002 | 07:27 PM
sshaikh01's Avatar
what kind of exhaust you got, around what rpm does your car do that.
Old May 4, 2002 | 07:33 PM
khoalie's Avatar
Default Re: Why am I backfiring? (sshaikh01)
yeah i have a tanabe g-power on my del sol and its does the samething
only at certain rpm and then only sometimes
i got used to it and even find myself likeing it
Old May 4, 2002 | 08:36 PM
Petah's Avatar
Default Re: Why am I backfiring? (khoalie)
Is a minor exhaust leak from the exhaust manifold and the cat bad for the car??
Old May 5, 2002 | 12:01 AM
kane2g's Avatar
Default Re: Why am I backfiring? (eg-six)
check timing/spark plugs/ cap and rotor.
maybe even cam timing if you got adjustable camgears
Old May 5, 2002 | 12:49 PM
Jonny G.'s Avatar
I have a catback Tanabe Racing Medallion with test pipe and mine does the same thing. I also have a fuel controller and I hear that if you lean your fuel out a bit It'll make you backfire. I have my fuel setting a little leaner than normal for daily driving gas economy. But is backfire usually a bad thing? Take turbocharged cars, or rally cars even, they backfire all the time with an additional flame at the end of the tailpipe.
LsDecepticon
Jun 22, 2014 11:51 PM
ray559527
37
Sep 4, 2011 05:42 PM
ilovejdm
Apr 29, 2011 02:55 PM
megaman_x
Sep 30, 2010 08:35 AM
lagger
Oct 9, 2002 07:15 PM
