Black stuff on my bumper from exhaust
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Did a quick search but nothing really. Ive been emitting it appears to be carbon from my exhaust onto my bumper. At first i used to just wipe it clean, but now its starting to really **** me off. How can I fix the problem. Am I running to rich?
And I know the Title is elementary sounding but thats the only way I could describe it. Flame away if you must.
and i just threw a CEL 22 code if that makes a difference as well
Getting it tuned will help, find out what that code is for. Do you have an adjustable fuel pressure regulator? If so try turning that down some.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlammedDC2 »</TD></TR><TR><TD CLASS="quote">Getting it tuned will help, find out what that code is for. Do you have an adjustable fuel pressure regulator? If so try turning that down some.</TD></TR></TABLE>
no i dont, should i get one? will get a tune up right away, should i replace the wires as well?
Modified by SupersonicBlueGSR at 8:21 AM 10/20/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by youngvedder »</TD></TR><TR><TD CLASS="quote">get it tuned, check o2 sensors....bad gas mileage - absolutely!</TD></TR></TABLE>
Its weird cuz im still getting 28-29 mpg, but i used to get 32-35
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonSirG »</TD></TR><TR><TD CLASS="quote">I get the black bumper too and my car is white
thats gotta really suck
</TD></TR></TABLE>thats gotta really suck
I had a gutted cat and it was too raspy, so I got a high flow one and when I did the change, there was a lot of carbon build up on the o2's, i wiped them off, but not that great, should I go back and clean them out, is there a specific cleaner I should buy?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupersonicBlueGSR »</TD></TR><TR><TD CLASS="quote">I had a gutted cat and it was too raspy, so I got a high flow one and when I did the change, there was a lot of carbon build up on the o2's, i wiped them off, but not that great, should I go back and clean them out, is there a specific cleaner I should buy?</TD></TR></TABLE>
I used my 3" exhaust for two hours and already my white bumper has black residue around the tip!!! I'll be running a bit rich since I was tuned with open dp.
Here's an idea... a clear coat scrub might help to aleviate the discoloration and excess charanuba wax might help to soak up some of the soot.
</TD></TR></TABLE>I used my 3" exhaust for two hours and already my white bumper has black residue around the tip!!! I'll be running a bit rich since I was tuned with open dp.
