Which lens do you think look best?
Old Oct 19, 2006 | 06:56 AM
hungtat's Avatar
Default Which lens do you think look best?
Got some high power bulbs for the corner lights. Which lens you think look better? Stock or clear? Is there any bulbs out there that are much brighter than these?
Modified by hungtat at 9:29 AM 10/19/2006
Old Oct 19, 2006 | 08:24 AM
ck123's Avatar
first one
Old Oct 19, 2006 | 08:30 AM
hungtat's Avatar
Default Re: (ck123)
Thanks and i think the same.
Still, anyone knows of brighter bulbs than these for the corner lights?
Old Oct 19, 2006 | 11:40 AM
Acco12dv6's Avatar
Default Re: (hungtat)
If you want brighter bulbs, look for LEDs.
Old Oct 19, 2006 | 11:48 AM
hungtat's Avatar
Default Re: (Acco12dv6)
I looked for LED before and the most I found was the 12 LED one which is more or less the same as these high power ones. I was wondering if there are other much brighter ones out there that I don't know about.
Old Oct 19, 2006 | 12:01 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acco12dv6 &raquo;</TD></TR><TR><TD CLASS="quote">If you want brighter bulbs, look for LEDs.</TD></TR></TABLE>
the thing about LED is that the project light only in some direction, if you use it in your signal, from far away you'll see one dot instead of a cluster of light(reflective defused for all of your physic geek). OEM or filament blub light up the refector in the rear to project the light.
second one looks cheap
how much light do you expect with a signal/corner? i don't know why people is so concern about lights. if you really want noticeable performance, get a retrofitted HID
Old Oct 19, 2006 | 12:04 PM
iam7head's Avatar
double post
92eg6lsvtec
Honda S2000
32
Jul 18, 2008 05:05 AM
blackcivic11
Lighting
Jan 21, 2008 07:32 PM
oddmut
Nov 25, 2005 12:20 AM
TealCivic93
Aug 30, 2005 10:58 AM
Viorent Grip! EG
15
Jun 7, 2004 01:54 AM
