Integra Type R Door Panel fabric?
Old Oct 19, 2006 | 06:54 AM
B20inDCinLBC's Avatar
Default Integra Type R Door Panel fabric?
Any body know where you can just get the fabric from the Red door panels? Is the fabric tweed or something similar to it? Has any one just made one themselves? Just curious.
Old Oct 19, 2006 | 07:38 AM
PhoenixDownVII's Avatar
Default Re: Integra Type R Door Panel fabric? (B20inDCinLBC)
While on that topic, are the inserts easily removable? If I get a replacement door panel but has a different insert, will I be able to swap it easily?
Old Oct 19, 2006 | 07:55 AM
GuitarSlinger78's Avatar
Default Re: Integra Type R Door Panel fabric? (PhoenixDownVII)
I was curious about this too. I replaced the fabric on the door panels on my old Integra. I couldn't figure out a way to just pop out the insert from another door (without breaking it). I ended up pulling up the other fabric since it's just glued on. Then cleaned up the area, masked it off, spray glued the other fabric in. With some work it came out pretty nice and looked stock.
Old Oct 19, 2006 | 10:34 AM
nautica_t's Avatar
1st, i don't believe you can pull off that panel.
and 2 tweed is correct, that is what you're lookign for.
Old Oct 19, 2006 | 10:42 AM
mystikalstriker's Avatar
Default Re: (nautica_t)
You just peels the fabric off. Remove the handle first but you just peel the fabric out. pry it out at the edges and slowly pull it off.
Old Oct 19, 2006 | 11:45 AM
so you guys who have answered already done this before?
Old Oct 19, 2006 | 02:23 PM
Default Re: (B20inDCinLBC)
Yeah, I just carfully pryed the fabric up and slowly pulled up grabbing the part closest to the plastic. I started off a little to fast and it started leaving some fabric behind. Just take your time it should come up no problem. I didn't run a blow dryer or heat gun over it but maybe that would help.
I initially was going to use fabric from a donor panel but that didnt work, I pulled it off and it just didn't look as clean. So I purchased very similar fabric (not cheap either) used the ones I pulled as a template and traced an outline then cut.
It is a little tricky to push the fabric into the recessed part of the door. To fix this (since adhesive didn't work in that small of a spot) was to get super glue (womens nail glue works too) and run a line of glue inside that panel crack, inset, recessed part, or whatever you want to call it. Then run a butter knife or something along to push the fabric down and your set.
*This is just how I did it, you can see the panels in my "pics of my old ride" thing
Old Oct 19, 2006 | 06:41 PM
Default Re: (JoE94Integ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoE94Integ &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, I just carfully pryed the fabric up and slowly pulled up grabbing the part closest to the plastic. I started off a little to fast and it started leaving some fabric behind. Just take your time it should come up no problem. I didn't run a blow dryer or heat gun over it but maybe that would help.
*This is just how I did it, you can see the panels in my "pics of my old ride" thing</TD></TR></TABLE>
good ****
Old Oct 20, 2006 | 12:05 AM
nautica_t's Avatar
looks good.
Old Oct 20, 2006 | 12:22 AM
Naruto's Avatar
I coulda sworn it was called "avus" fabric.....
I'm gonna go look it up
*edit* found it ( search does wonders )
https://honda-tech.com/zero...age=2
scroll down to not so civic's post.
Old Oct 20, 2006 | 01:55 AM
EnjoyTheRideDC2's Avatar
Default Re: (Naruto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naruto &raquo;</TD></TR><TR><TD CLASS="quote">I coulda sworn it was called "avus" fabric.....
scroll down to not so civic's post. </TD></TR></TABLE>
That looks like it would cost an arm and a leg to have sent to the US...
Almost makes me more interested in just buying the panels.
Old Oct 24, 2006 | 12:01 AM
Naruto's Avatar
Default Re: (EnjoyTheRideDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnjoyTheRideDC2 &raquo;</TD></TR><TR><TD CLASS="quote">
Almost makes me more interested in just buying the panels.</TD></TR></TABLE>
I got mine for $150 shipped....but that was a while ago. To me...it was worth every penny ( especially since they were mint and included the cf switch covers ! )
Old Oct 24, 2006 | 02:43 AM
I got mine for $150 shipped....but that was a while ago. To me...it was worth every penny ( especially since they were mint and included the cf switch covers ! )</TD></TR></TABLE>
Agreed...the cost of fabric and shipping, materials, and time...yeah, buying them would be worth it.
Old Oct 24, 2006 | 05:33 AM
AudioXtremes's Avatar
OMG!!! Type R fabric!!!
You guys are weird.
Old Jul 9, 2009 | 06:49 PM
richerich284's Avatar
i have the authentic type r door panel fabric
check out my listing on ebay
in search type in: door panel inserts
username: abram246
suhteevin
Jan 6, 2009 09:04 PM
trick_db
Jul 26, 2006 09:29 AM
Red1ine
Nov 7, 2005 01:42 PM
BolivianDc2
Jun 9, 2004 08:26 AM
Havokmkr
Jul 25, 2003 08:10 AM
