GSR oil cooler tech question
Old Oct 19, 2006 | 05:26 AM
ykracing's Avatar
Default GSR oil cooler tech question
Guys, I was wondering if anybody has a diagram, or knows the direction of flow through the GSR sandwich oilcooler?
I am thinking about doing some modificationns to that system, but I cant seem to find anything that explains where the external hoses go to and from...
tia!
Old Oct 19, 2006 | 07:14 AM
Wes V's Avatar
Default Re: GSR oil cooler tech question (ykracing)
One of the water lines comes from the water "cross-over" pipe that runs along the back of the block.
The other line goes to a fitting on the back side of the block (when I say "back", I'm refering to the side of the engine closest to the firewall).
I think that the water pressure is higher in the cross-over pipe than in the block (but could be wrong), which means;
The water flows from the cross-over pipe, through the intercooler body, and then back into the block.
If you look inside the intercooler, I think you would realize that the direction of the water flow shouldn't make any difference.
Wes
Old Oct 19, 2006 | 07:19 AM
ykracing's Avatar
Default Re: GSR oil cooler tech question (Wes V)
cool, thanks for the info... but the direction will matter for what I am trying to do...
so you think that the hard pipe is higher pressure huh?
Modified by ykracing at 11:43 AM 10/19/2006
Old Oct 19, 2006 | 07:37 AM
Bense's Avatar
here's a pic of a d15z1 where I robbed the oil cooler. this may help
Old Oct 19, 2006 | 07:45 AM
ykracing's Avatar
thanks guys.. I found a diagram, but now its just trying to confirm the flow direction of the coolant through the cooler itself...
Old Oct 20, 2006 | 06:27 AM
ykracing's Avatar
Default Re: (ykracing)
anybody else?
Old Oct 20, 2006 | 03:45 PM
Wes V's Avatar
As I said in my prior post, one hose goes to the water cross-over pipe and the other goes to a fitting on the block.
The cross-over pipe <U>has</U> to have a higher pressure due to it's being right at the output of the water pump!
Go to the dealer (or look at one of the on-line dealers) and get the diagram showing the hoses. Then see which hose fitting on the cooler is hooked to the cross-over pipe. That's the "input" to the intercooler.
All that said, I still think that it doesn't matter as to the direction of water flow within the intercooler.
Wes
Ron Burgandy
Jul 13, 2014 10:29 AM
dturbo
Apr 24, 2008 03:00 PM
travis-b16a2-eg
Jun 22, 2007 08:32 PM
Timmay
12
May 17, 2007 05:14 PM
TwoKSiR
May 2, 2007 01:43 PM
