1st gen b16a help
well im building a project crx and i have couple of mods done, but my problem is will this run right on stock injectors, jdm p30 ecu, and stock fuel rail, and stock fuel pump? and my sponsor dave hickman racing said he has a chip for me to run but how accurate will it be, is running a preset chipped ecu with no tunning bad?
mods to my project crx
B16a from HMO(Roughly 52,XXX)
*Denso Iridium spark plugs
*NGK Spark plug wires
*Hasport Mounts
*S1 tranny act stage 3 clutch
*cheapo Intake
*B&M no bend short shifter
*Energy shifter bushings
*New intake manifold gasket(installed)
*JKOBD conversion(Car is OBD1)
*Battery relocated to the back with SCCA approved battery box
*75/69mm dh-racing throttlebody
*dh-racing ported and port matched typhoon inatke manifold
*toda cam gears
*ctr cams
Exhaust
*DC sports 4-2-1 Header
*Omnipower test pipe
*Greddy SP 2 Exhaust
*Hasport Mounts
*cheapo Intake
*toda cam gears
*ctr cams
Exhaust
I have similar mods on my crx although I still run the stock obd0 pr3 ecu. It may not have as much power as a tuned ecu, but should run fine nonetheless as long as you have to mechanical/electrical problems. I have the bold items.
*Redshift Racing Mounts (old school)
*cheapo Intake
*toda cam gears
*ctr cams
Exhaust
*RSR Header
*Vibrant Hi-Flow Cat
*Tanabe Hyper Medallion Exhaust
*cheapo Intake
*toda cam gears
*ctr cams
Exhaust
*RSR Header
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">Do you know for sure that the motor only has 52,xxx miles on it?</TD></TR></TABLE>
rextec
Feb 14, 2005 12:14 PM
