crx headlight removal?
Old Oct 18, 2006 | 10:30 PM
supracrx's Avatar
Default crx headlight removal?
does the bumper have to come off to remove the headlight? there is the two bolts on top hoilding the bracket and one from the corner light so....but it doesn't seem like it wants to come off? is there another bolt under that i can't see?
Old Oct 19, 2006 | 09:55 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: crx headlight removal? (supracrx)
Yes you have to take the bumper off to access the last bolt you need to remove.
Old Oct 19, 2006 | 10:03 AM
supracrx's Avatar
thanks i broke the adjustment tab on the headlight and now i need a new one...just need to make sure i can remove it
Old Oct 19, 2006 | 05:11 PM
ef 4 door's Avatar
Default Re: (supracrx)
what do u mean, I replaced my light on my rex and I did not have to take the bumper off. use a long extension with 1/4 drive and some swivels.
Old Oct 20, 2006 | 11:25 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (ef 4 door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef 4 door &raquo;</TD></TR><TR><TD CLASS="quote">what do u mean, I replaced my light on my rex and I did not have to take the bumper off. use a long extension with 1/4 drive and some swivels.</TD></TR></TABLE>
Yes, this is possible as well, but I find it to be more of a pain in the *** than taking off the bumper.
Old Oct 21, 2006 | 09:29 AM
ef 4 door's Avatar
Default Re: (wiZCo)
it justs seems that it is more work 2 take the bumper off, than having the "right tools for the right job". this is a saying that I grew up with. but to each his or her own.
have fun in the headlight removal & install. remember 2 double check everything.
Old Oct 21, 2006 | 10:06 AM
HBK's Avatar
HBK
It takes like 5 minutes to take the bumper off. Its worth it to get the headlight correctly out and installed.
Old Oct 24, 2006 | 05:07 PM
ef 4 door's Avatar
Default Re: (HBK)
hey thanks for the info. I will try this next time I have to replace my headlights
innes887
Jun 14, 2007 11:47 AM
s13_240sx_92
Nov 24, 2004 10:07 AM
azian21485
May 11, 2004 08:13 AM
2k1_ITR_0736
Feb 13, 2003 03:57 AM
BlackCRX
Aug 29, 2001 05:42 AM
