02 accord coupe steering wheel audio switch
Old Oct 18, 2006 | 09:36 PM
honda genome
Guest
Posts: n/a
Default 02 accord coupe steering wheel audio switch
Sup ya'll my audio switch on the steering wheel for the radio doesnt work.....anyone know what is wrong with it? How to fix it? When i press it nothing happens, like its not plugged or something....thanks in advance
Old Oct 19, 2006 | 06:34 PM
honda genome
Guest
Posts: n/a
horn is not working either
Old Oct 24, 2006 | 07:57 AM
honda genome
Guest
Posts: n/a
for future reference, I took out the whole steering column and traced the wires to see if anything was loose, to my dismay everything was intact....then I fooled around w/ the SRS coil thing, the spindle wires that twist around to allow turning of the steering wheel and allow electrical devices to be operated...well it seems that is the culprit, it is faulty somehwere...as i messed with it i started working and I put everything back together thinking it might have been a glitch...as I was driving however and made a turn to the right everything stopped working again....horn, audio switch, so i went back home and dismantled everything thinking it had to be turning related,k since i turned right i decided to keep turning the coil to the left a few times to allow for access of easy turning and I guess that solved the problem so far, but the wierd thing is the cruise control light shows up on the dash just doesnt work for some unknown reason....if anyone knows the cause of this or anything about the SRS coil thing behind the steering wheel any help would be great....thanks
Angelene Aponte
Honda Civic (2006 - 2015)
May 29, 2018 12:13 PM
beans45883
Jun 16, 2017 06:35 AM
WaryDriver
Jan 29, 2016 07:32 PM
accordredliner
Feb 19, 2006 12:26 AM
