MILLED HEAD W/ FLAT TOPPED PISTON vs. HIGH DOMED PISTONS
Old Oct 18, 2006 | 08:49 PM
GetSTROKED's Avatar
Default MILLED HEAD W/ FLAT TOPPED PISTON vs. HIGH DOMED PISTONS
I was always curious of what advantages or disadvantages of each approach would be to achieving high compression results (milled head/flat topped pistons vs. high domed pistons). I would love to hear peoples opinions and theories on this matter.
Old Oct 18, 2006 | 09:12 PM
Combustion Contraption's Avatar
Milling the head effectively reduces p2v clearance but so do large domed pistons. The ideal dome on a piston is still no dome at all. Unfortunately, to achieve some compression, a dome is needed.
Old Oct 18, 2006 | 09:56 PM
alterdcreations's Avatar
Default Re: (Combustion Contraption)
domed piston with milled head
go for the max
Old Oct 19, 2006 | 08:56 AM
ranta18's Avatar
Default Re: (alterdcreations)
Milling the head on a head like the H22 will decrease your quench height (top of piston to bottom of chamber quench pad). This is good. You will also want to clay the pistons. Shoot for a minimum piston to head quench pad clearance of .030, a minimum piston to intake valve clearance of .040, and a minimum piston to exhaust valve clearance of .060. As CC said above, the flatter the piston the better for flame propogation, but you can only mill the head so far so you have to fill up the chamber with dome.
Old Oct 19, 2006 | 09:08 AM
drift4jesus's Avatar
Default Re: (ranta18)
Smaller dome on the piston is good for 2 things. Better flame travel (like already stated) and allowing the piston to be lighter reducing rotating mass.
Old Oct 19, 2006 | 10:28 AM
Wuhhht Duhh's Avatar
Default Re: (drift4jesus)
i was wondering how hard is it to clay a motor? can you DYI?
Old Oct 19, 2006 | 10:32 AM
ranta18's Avatar
Default Re: (Wuhhht Duhh)
Look here: http://www.rndauto.com/rantabuild3.htm
Old Oct 19, 2006 | 03:00 PM
JDogg's Avatar
dome filling the chamber dosnt effect honda's nearly as much as some other engines... fill the chamber up and let it roll
Old Oct 19, 2006 | 03:39 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: MILLED HEAD W/ FLAT TOPPED PISTON vs. HIGH DOMED PISTONS (GetSTROKED)
A high dome can also hinder flow coming out of the valve. The extent of this will greatly depend on the motor though.
sh4k3r
Aug 3, 2012 03:03 PM
95accord3267
Feb 28, 2012 12:03 PM
SilverEk3dr
Apr 30, 2009 07:53 AM
rodimus
Aug 7, 2003 02:38 PM
redman223
May 13, 2002 05:58 AM
