Axle Removal
I am having trouble getting the axles off. I first took off that huge 32 mm bolt, and then i took the bolt off that connects to the steering wheel and disconnected that. How does that ball joint separeter come into play? Was i suposed to disconnect the steering control arm? I'm Confused???? help please. thanks in advance.
This is an excellent pictorial of how to do it.
http://www.c-speedracing.com/howto/b18cswap/swap.html
A. Here's how to pull the axles:
Tools you'll need if doing a Civic or Integra:
19mm for the wheel
32mm big-*** socket and BIG rachet for it - to break off and tighten back up the axle nut
17mm wrench
17mm wrench again or rachet
Dykes
Hammer
Prybar
TRY to get the entire front of the vehicle off the ground so you can turn the wheels to make things easier.
1. Take the wheel off with the 19mm
2. Take the 32mm nut off the end of the axle
3. Take the dykes and pull the cotter pin out of the bottom 17mm castle nut on the lower balljoint
4. Take the 17mm and remove the castlenut from the lower balljoint
5. Take your big-*** hammer and whack right ON the lower control arm where the balljoint sits - this method for buting the balljoint out will not tear the balljoint boot like the "balljoint wedge" will
6. Take both 17mm and remove the thru-bolt that runs through the lower fork of the front stut - this will allow the axle to slide out when ready by pulling the strut fork to the side of the lower control arm
7. Pull the brake rotor out of the way - axle is ready to come out
8. Take the prybar and pry the axle by prying between the inner joint and the tranny housing
**CAUTION**
If it's a manual tranny you NEED to drain it if you're doing the PASSENGER side on a car with equal-length driveshafts - if it's a B-series this applies. Unequal length shafts will require yopu to ALWAYS drain the tranny.
Reassamble it how you disassembled it. Only then you need to stake the axle nut down by putting a dent in it and do'nt forget to replace the cotter pin in the lower balljoint castlenut!
19mm for the wheel
17mm wrench
Dykes
Hammer
Prybar
**CAUTION**
19mm for the wheel
17mm wrench
Dykes
Hammer
Prybar
**CAUTION**
19mm for the wheel
17mm wrench
Dykes
Hammer
Prybar
**CAUTION**
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">Oh come on now - I spent at least 20 minutes typing that up. At least give some credit where it's due y0! </TD></TR></TABLE>
B18C5-EH2 Credit
B18C5-EH2 Credit
You don't even have to mess with the ball joints, unbolt the lower control arm from the frame, unbolt the radius rod and the shock fork, and it'll swing out of the way without breaking the balljoint.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx »</TD></TR><TR><TD CLASS="quote">You don't even have to mess with the ball joints, unbolt the lower control arm from the frame, unbolt the radius rod and the shock fork, and it'll swing out of the way without breaking the balljoint.
the ball joints easy just hit the lower control arm with a hammer and the ball joint will loosen itself out no need to loosen 3 extra bolts when you don't need to. also if you use the hammer way it won't **** up your ball joint like a ball joint seperator would.
