i need a custom diy turbo system useing parts off a talon or eclipse
Old Oct 18, 2006 | 06:58 PM
flatblk's Avatar
Default i need a custom diy turbo system useing parts off a talon or eclipse
i have a b18 and want to turbo it i wanna make my own it ne infos i have some parts out of a taon that i can use? i know on the sohc motors u could use the injetcors and the turbo can a do the same?
Old Oct 18, 2006 | 07:36 PM
elrandeeto's Avatar
Default Re: i need a custom diy turbo system useing parts off a talon or eclipse (flatblk)
you can use the bov , injectors(450's from 90 to 92 tsi gst gsx ) but if your motor is obd1 you need to buy a resistor box . You can also use the 14b turbo from 1st gens just need to have a flange put on whatever manifold you choose . The side mount intercooler will also work , not the best but it will work . so you will have to buy a turbo manifold , something for tuning, oil feed and drain lines , charge piping and a few other misc. oh and i think the 14bs are watercooled so lines for that .
andreysibiris
13
Jan 17, 2006 12:03 PM
cL2.2
Sep 7, 2005 10:03 AM
coldfiremx
Mar 5, 2003 04:30 AM
darkstarsi
Feb 3, 2003 04:58 AM
