GSR Burning Oil what causes this..
Old Oct 18, 2006 | 06:42 PM
0260MOTORSPORTS's Avatar
Default GSR Burning Oil what causes this..
Ok i did a compression check on my New rebuilt GSR fit for high compression and im getting 185 psi across all 4 cylinders and yet im still burning oil...Can anyone throw out some ideas as for this..
Old Oct 18, 2006 | 06:47 PM
Vtech Girl's Avatar
PCV valve?
can you see smoke from the rear or do you just notice the oil level going down?
Old Oct 18, 2006 | 07:03 PM
Combustion Contraption's Avatar
Default Re: GSR Burning Oil what causes this.. (0260MOTORSPORTS)
What do you consider high compression?
Old Oct 19, 2006 | 08:57 AM
Default pcv
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtech Girl &raquo;</TD></TR><TR><TD CLASS="quote">PCV valve?
can you see smoke from the rear or do you just notice the oil level going down?</TD></TR></TABLE>
I see smoke and the i need to refill like every 3-4 weeks im going to try the PCV and let you know..As far as high compression i consider anything over 11.5 is high compression...WHY..What does it have to do with the question..
Thank you
Old Oct 19, 2006 | 07:26 PM
Default Re: pcv (0260MOTORSPORTS)
BUMP&gt;&gt;&gt;&gt;
Old Oct 19, 2006 | 08:17 PM
SkoundrelUSA's Avatar
cute little bastard
11.5 isn't "crazy high" and I think your numbers should be higher than 185 if you are 11.5:1. Mines around 11.6 and I'm in the 240psi range.
I'm also having a similar burning problem. valve seals maybe?
Old Oct 19, 2006 | 09:15 PM
hayabusa160's Avatar
Default Re: pcv (SkoundrelUSA)
im on the same boat. comp is 240ish
11.6 comp
im guessing its the valve seals.
i burned almost 2 quarts of oil driving to canada and back. i also did a 30mins track event in canada also.
it only dose it at high rpm. but its been doing it for almost 3 years i had it lol.
Old Oct 20, 2006 | 05:59 AM
cute little bastard
Default Re: pcv (hayabusa160)
lol 3 years?
You didn't bother putting in new seals yet?
Old Oct 20, 2006 | 08:37 AM
nah. going to rebuild it next year lol
it never got worste so whatever hahah
Old Oct 20, 2006 | 10:51 AM
MikeSarr_GSR's Avatar
running alot of timing advance on an untuned setup can eventually lead
to this. it can also mean that your rings have become frozen and they
arent scrubbing very well anymore. it can also mean that they are
stuck in an unideal area of the piston where the ring gaps are overlapped
and gives the oil and spent gases a easy means for escape. if you are
losing oil from this, you are losing some power as well.
Old Oct 21, 2006 | 08:23 AM
Thanks for the help yeah i get smoke at high REV..I installed new valve seals maybe one was bad the smoke doesnt smell like oil burn kinda like fumes but there is faint white smoke...
type_r_teggy
Dec 8, 2008 02:44 PM
ah789454
Nov 14, 2004 03:03 PM
Jet Black
12
Jun 8, 2004 08:05 PM
Bbasso
Sep 17, 2003 03:22 PM
