BRAKE MASTER CYLINDER LEAK?? PEDAL SINKING?
Old Oct 18, 2006 | 05:22 PM
4play4dr's Avatar
Default BRAKE MASTER CYLINDER LEAK?? PEDAL SINKING?
alright honda-tech..i THINK i might have a leak in my brake master cylinder because that **** keeps running low after a day of driving..and my pedal sinks to the floor and isnt stiff..do i need to bleed it again? btw..i just did a 5lug conversion and this happened.. so any help is appreciated because i dont wanna have to keep buying brake fluid to refill it every week or two..
i tried searching and people only have leaks that are noticable..i dont see any leaks.. so i dunno what to do if i should try bleeding it again or if i should get a new master cylinder..this is a 95 integra RS (non-abs)..
any help appreciated..thanks in advanced
Old Oct 18, 2006 | 07:44 PM
Blazineyez's Avatar
Default Re: BRAKE MASTER CYLINDER LEAK?? PEDAL SINKING? (4play4dr)
Ight man I had the same problem on teg.....so i ended up buyin a new brake master cylinder and after that I never had a problem with it....best thing to do would to replace it.
Old Oct 19, 2006 | 07:47 AM
thesmogman's Avatar
Look right below the master cyl, on the booster. Look real good. I had been looking for my brake problem for a while and I swore it wasn't leaking. But it was.
It doesn't show up good on the brake booster look below it too on the cross member and firewall.
If it isn't the MC (which I think it is) Then it's possible one of the wheel cylinders might be leaking. For this look at the inner side of the tires for fluid. You might want to pull the rear drums and check them too.
I wouldn't take a chance with brake issues. Check them good!
Old Oct 19, 2006 | 05:32 PM
4play4dr's Avatar
Default Re: BRAKE MASTER CYLINDER LEAK?? PEDAL SINKING? (Blazineyez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blazineyez &raquo;</TD></TR><TR><TD CLASS="quote">Ight man I had the same problem on teg.....so i ended up buyin a new brake master cylinder and after that I never had a problem with it....best thing to do would to replace it.</TD></TR></TABLE>
u had the same problem..as in..fluid keeps draining but no signs of leakage? i guess i gotta try to get a new MC and hope that cures my problem
also..is there a difference in an ABS MC and a NON-ABS MC?? just wanna know what to search for
Old Oct 21, 2006 | 06:41 PM
4play4dr's Avatar
i guess i gotta change my brake master cylinder and hope if fixes it..anyone got a write up on changing this?
Old Nov 13, 2006 | 07:08 AM
WHAT TEH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4play4dr &raquo;</TD></TR><TR><TD CLASS="quote">
also..is there a difference in an ABS MC and a NON-ABS MC?? just wanna know what to search for</TD></TR></TABLE>
more likely, a non-ABS MC will use two 10mm fittings. an ABS-equipped MC will use one 10mm and one 12mm fitting. these are for tha stainless steel lines. that 12mm fitting on ABS-equipped MC's are meant to go directly to tha ABS modulator. on non-ABS vehicles, they go directly to tha proportional valve.
_taF
Old Nov 26, 2006 | 08:35 PM
r126's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4play4dr &raquo;</TD></TR><TR><TD CLASS="quote">i guess i gotta change my brake master cylinder and hope if fixes it..anyone got a write up on changing this?</TD></TR></TABLE>
Here's an article from TI:
http://www.team-integra.net/se...D=992
another eg
Sep 1, 2015 04:31 PM
AWD: Jeff
Suspension & Brakes
Jul 3, 2010 06:47 AM
integra123
Aug 8, 2006 05:52 PM
MrEg
Sep 22, 2003 04:49 PM
dave94ex
Mar 10, 2003 03:55 AM
