Could be Getting a b16 Head
Old Oct 18, 2006 | 04:40 PM
crawlin's Avatar
Default Could be Getting a b16 Head
well i might be purchasing a b16 head port and polish crower valvetrain with flat faced valves, with a aebs intake manifold with ported 70mm inlet and runners ported to match head. My question is with the b16 head will my compression drop(becasue of going to a b16 head from a gsrhead ) if so thats most likely a good thing because im running 0.25 ctr pistons. But because of the flat faced valves will it just basically be the same comp. ratio as i have now right now i just have stock valves on my gsr head. also i will just be throwing my ef-1 m23 cams that im running now any opinions on the cams.
also im getting the head from DIFFUT'S INC any opinions on his building quality.
Old Oct 19, 2006 | 04:08 PM
crawlin's Avatar
Default Re: Could be Getting a b16 Head (crawlin)
anybody?
Old Oct 19, 2006 | 05:21 PM
NJIN BUILDR's Avatar
You would need to measure the combustion chamber size to be sure.A b16 that has been milled alot can be smaller than a stock gsr.
Old Oct 20, 2006 | 07:00 PM
crawlin's Avatar
Default Re: Could be Getting a b16 Head (NJIN BUILDR)
was looking for some more reply's
jayswizz
Oct 7, 2015 06:34 AM
adam00
Apr 21, 2009 09:18 PM
96lsintegra
Jun 28, 2006 10:09 AM
Spectrum24x
Feb 10, 2005 06:50 PM
J-Spec EG
14
Sep 15, 2004 06:48 AM
