Steering Column has play in it...
Old Oct 18, 2006 | 02:19 PM
nk2k2's Avatar
Default Steering Column has play in it...
My steering column has play it it. i have a momo steering wheel w/ the hub adapter and i can easily move the steering wheel up and down and left and right. its like checking for a bad wheel bearing and i think it might be the same case with the steering column. I know that they have upper and lower bearings and i think my upper bearing is toast. I wanted to know if any of you have ever experienced this and is it easy to take apart and replace. I have removed the steering wheel itself and impacted the nut that goes in between and still no luck.
Old Oct 18, 2006 | 03:12 PM
nk2k2's Avatar
Default Re: Steering Column has play in it... (4g4d)
anyone know?
Old Oct 18, 2006 | 04:21 PM
Jonathan_ED3's Avatar
is your steering wheel tight at all of the bolting positions? there's a total of 5 I believe. One in the middle of your column down above the pedals, and then two sets of 2 right underneath your dashboard. Check to make sure the bolts/nuts at all those positions are tight. They are all 12mm if I remember correctly.
Old Oct 18, 2006 | 04:42 PM
CP9A6M's Avatar
Default Re: (Jonathan_ED3)
Do you have power steering?
Old Oct 18, 2006 | 05:43 PM
nk2k2's Avatar
Default Re: (CP9A6M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_ED3 &raquo;</TD></TR><TR><TD CLASS="quote">is your steering wheel tight at all of the bolting positions? there's a total of 5 I believe. One in the middle of your column down above the pedals, and then two sets of 2 right underneath your dashboard. Check to make sure the bolts/nuts at all those positions are tight. They are all 12mm if I remember correctly.</TD></TR></TABLE>
i will check tomm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CP9A6M &raquo;</TD></TR><TR><TD CLASS="quote">Do you have power steering?</TD></TR></TABLE>
yes, why would that matter?
Old Oct 18, 2006 | 06:44 PM
higgunscrx's Avatar
bump cuz i got the same issue, my steering wheel shake at high speeds and when braking, i got all new balljoints upper and lower, inner and outer tie rods and a new steering rack. feels like there is play up and down in the steering wheel when it is locked in any position. plus when i rock the wheel back and forth i can hear a sound comming from the lower part of the colum area. also sometimes when i'm driving the steering wheel feels wavy.
gonna check the mouting bolts under the dash tomorrow.
anyone else got any other ideas?
Old Oct 19, 2006 | 04:22 AM
nk2k2's Avatar
Default Re: (higgunscrx)
i havent heard any noises or anything as of now. i do get a slight shimmey which is not too annoying.
Old Oct 19, 2006 | 05:18 AM
Furyof4's Avatar
Default Re: (4g4d)
Check the universal joint on the bottom of the column.
Old Oct 19, 2006 | 09:07 AM
rsca_crx's Avatar
Default Re: (Furyof4)
you have the column adjuster locked, right?
check that the wheel nut is tight and that the adapter is on there right. if so, continue.
if it is moving up and down in the plane of the wheel (like a wheel bearing) it is probably the bolts un the middle of it that hold it to the firewall extension and the brace. also check that the brace is there/bolted.
the u-joints will allow movement forward and aft, like pulling it into your chest. if unchecked, they will also start to loose their teeth, which will give more play in the turning of the wheel, and eventually strip all the way out and leave you with a car that doesn't turn. it is especially fun when this happens while you are moving.
Old Oct 19, 2006 | 01:42 PM
CP9A6M's Avatar
Default Re: (4g4d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g4d &raquo;</TD></TR><TR><TD CLASS="quote">yes, why would that matter? </TD></TR></TABLE>
Cuz if you had a power rack but converted to no power there would be hella play in the rack
Old Oct 19, 2006 | 02:49 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CP9A6M &raquo;</TD></TR><TR><TD CLASS="quote">Cuz if you had a power rack but converted to no power there would be hella play in the rack</TD></TR></TABLE>
No, there wouldn't be any additional play.
Old Oct 19, 2006 | 04:35 PM
CP9A6M's Avatar
Default Re: (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
No, there wouldn't be any additional play.</TD></TR></TABLE>
If you took the valve body off there will be, the bearing sleeve with the pin in it will be free to move around, i've seen this happen before, but that's besides the point since he still has PS.
Old Oct 19, 2006 | 05:23 PM
nk2k2's Avatar
does anyone have pictures of the parts that are all describled above?
civic4life8045
18
Jun 5, 2013 09:10 AM
niceprelude
Jan 30, 2009 07:50 AM
b18cEK
Mar 23, 2004 06:48 AM
AGNSoncite
Nov 14, 2003 01:03 PM
